1Back to top Go down   The Whistler Empty The Whistler Thu Nov 08, 2012 1:56 pm
eastern_phoenix
eastern_phoenix
I am a boxer rider of many years but I have just aquired a 1985 2 valve K100RT. I've
had a bit of fetling to do (new plugs, was fitted with incorrect grade,
choke lever replaced, throttle switch reset it was holding off the
throttle stop and causing a minimum tick over of 1300, reset idle speed.
reset choke stages and varios tidy ups) and it now seams to run pretty
well but does take a bit of getting used to all those revs.
HOWEVER I
am a little dubious about the sound I have a constant whistle, rev
related, like a turbine, if it were turbo charged I would say that was
it is. Sounds a bit like a Class47 Diesel. Is this normal?
hope it is !!!!! can any one help. The Whistler 652573
2Back to top Go down   The Whistler Empty Re: The Whistler Thu Nov 08, 2012 2:12 pm
nino
Welcome, dont worry about whistle. Its fuel pump normal sound. Somebody call K 100 engine - whistler
3Back to top Go down   The Whistler Empty Thanks Thu Nov 08, 2012 3:08 pm
eastern_phoenix
eastern_phoenix
Many thanks I did think it may be a characteristic. cheers
4Back to top Go down   The Whistler Empty Re: The Whistler Mon Nov 12, 2012 2:26 am
Themason
Themason
[quote="nino"]Welcome, dont worry about whistle. Its fuel pump normal sound. Somebody call K 100 engine - whistler[/quote]
Whistler? More like the toaster!
1986 R-80G/S w/1000 cc engine
Similar topics
» Where is my car?
