1Back to top Go down   What is it? Empty What is it? Wed Sep 04, 2013 1:10 pm
klamityboy
klamityboy
When I was replacing the fuel lines, I noticed the cutoff end of a wire near between the fuel pressure regulator (labelled A in the picture) and the breather tube (labelled B in the picture). I asked at the local dealer and the response was "some kind of sensor". Since they were not sure what it was, they couldn't tell me what it did, or if I needed it.
Can you help me identify the circled item (keep in mind there was a cable there originally but it has been cut off).
What is it? Bmw_ph10
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
2Back to top Go down   What is it? Empty Re: What is it? Wed Sep 04, 2013 3:03 pm
japuentes
japuentes
Hi there, looks to me that's the "Choke" light switch.
Best regards
JAP
What is it? 2854237993 1988 K100RS SE/ABS
3Back to top Go down   What is it? Empty Re: What is it? Wed Sep 04, 2013 4:44 pm
klamityboy
klamityboy
japuentes wrote:Hi there, looks to me that's the "Choke" light switch.
Best regards
JAP
Which might explain why the choke light does not come on even though the bulb was replaced during the LED bulb upgrade.
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
4Back to top Go down   What is it? Empty Re: What is it? Wed Sep 04, 2013 5:21 pm
Link
Check out number 13 if the link has worked. Stupid ipad.
I believe jap is correct
Then go find a new local dealer, yours obviously has no idea.
5Back to top Go down   What is it? Empty Re: What is it? Wed Sep 04, 2013 6:09 pm
Check this
This is the same switch as the clutch switch, or the front or back brake switch.
Easy to find.
Usually, they are just sticky and a good cleanup of the plunger will solve the problem.
Yours may not have been adjusted correctly and this could be the only problem.
CF
What is it? Frog15What is it? Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
6Back to top Go down   What is it? Empty Re: What is it? Wed Sep 04, 2013 7:54 pm
klamityboy
klamityboy
rossko wrote:Link
Looks right. What/where does the other end plug into?
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
7Back to top Go down   What is it? Empty Re: What is it? Wed Sep 04, 2013 8:18 pm
klamityboy wrote:Looks right. What/where does the other end plug into?
Into a a two prong black connector on the left side of the main wiring harness under the tank, near the fan.  How do I know?  Because my fan turned on once and sliced right through my switch wire (which happened to be dangling too close), causing my choke light to malfunction.
8Back to top Go down   What is it? Empty Re: What is it? Wed Sep 04, 2013 8:23 pm
klamityboy
klamityboy
Thanks.
Obviously the bike will run without this as I have not had a visible choke light since I have owned the bike (17years). It also appears that the wire was deliberately cut. I guess I will think about replacing it down the road sometime. Unless there is a compelling reason to do so sooner!
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
