1 HELP - I've messed up my speed sensor Mon Oct 22, 2012 4:17 pm
colinijohnson
Bad day today - firstly I dropped the bike on the toolbax, cracking the fairing!
Secondly - I was on a mission to clean all connections - I carefully removed the speed sensor from the rear bevel and the noticed a small washer clung to the magnetic. Not being very apt or technical, I assumed the washer went on the end of the sensor, and put it all back on!
MMm I think the washer was off the allen fixing bolt, and guess what?? my speedo now wont work!
I took it off and now can't see the washer, plus the sensor rubber looks slightly worse for wear too.
Please help - Is it best to just try a replacement sensor? (I notice BMW have discontinued now) - will the washer in the bevel cause a problem? will it drain out - or should I replace the bevel (I have a spare).
Or have I missed a trick here ?
Thanks for any help
Colin
Thanks for any help
Colin
