1 Inductive speed sensor replacement Fri Aug 19, 2022 5:16 pm
flying finn & brick
Report about my way to replace broken K75 K100 speed sensor. I broke it by removing it from the final drive. So don't remove the speed sensor, just unplug it!
I got upset after I realised the sensor was broken only because of my unnecessary actions. I got more upset after seeing the price 80-150€ for new sensor + the wait for it to arrive. The 30€ used one didn't sound too good either. So I decided to find a replacement from some local auto parts store.
There could be many more and better alternatives but this was the one I found feasible and was available.
The replacement sensor is Opel crank shaft sensor. Intermoto 18987. Like this:
CRANKSHAFT POSITION SENSOR 18987 for OPEL ASTRA FIAT 10456604 1238938 71739726 | eBay
I got it for 25€. It is much more inexpensive than the original and brand new. The original sensor is 14,5mm in diameter while this one is 13,5. It leaves space for some thin o-rings to seal the hole. The original sensor should be 3k ohms (correct me if I am wrong) and the replacement part is 2,38k ohms.
I measured the signal from the sensor with oscilloscope and it should be fine. I don't have a working original sensor so can't compare but I did compare with K-diag speed signal. It works up to 100km/h. 100+ kmh i have no data. In theory the signal voltage could climb too high with enough speed. The sensor has smaller diameter and smaller resistance -> I assume the coil is smaller so it should't happen.
I added some electrical tape and o-rings so it would sit nicely on the hole. The screw hole was to far away from the sensor so I enlarged it a bit. I also soldered the original wires to the sensor.
Thoughts? Should this be added to the tech page? It isn't a straight fit but seems to work nicely.
