1Back to top Go down   oil weight causing my leak? Empty oil weight causing my leak? Sat Oct 06, 2012 11:14 am
KlaustheK
KlaustheK
I recently changed my oil and ended up using lighter weight synthetic (15 w 50). I had 15 w 30 in it for the summer. Is this weight change why i suddenly have several small drip leaks? That is my current theory.
1987 K100RS Klaus *sold*
1989 K100RS SE Klaus 2 *sold*
1997 K1100LT Gunter
2Back to top Go down   oil weight causing my leak? Empty Re: oil weight causing my leak? Sat Oct 06, 2012 12:22 pm
Toto_jp
No the leak would have been there before unless its the oil filter cover leaking then you didn't clean it up before replacing it
also that new oil is actually a heavier weight oil the 15 is the light oil and 50 is heavy oil for when engine gets hot
Cheers Tony
K100 RS 1986
3Back to top Go down   oil weight causing my leak? Empty Re: oil weight causing my leak? Sun Oct 07, 2012 12:27 am
Motorandy123
Motorandy123
Synthetics can clean the junk out that is sealing various seams on the bike. In the old days
it would cause seals to leak too but they supposedly use seal sweller now. 50W should be
thicker. You can fix the leaks or go back to dino (and possibly have trouble with the starter
sprag)...
MotoRandy123
1991 K75 "Special Edition"
4Back to top Go down   oil weight causing my leak? Empty Re: oil weight causing my leak? Tue Oct 30, 2012 2:43 pm
KlaustheK
KlaustheK
News: Klaus heals himself. After about two weeks of slow drippage ( 5-8 drops a day) the leaking has stopped. I think the "seal swellers" have kicked in.
1997 K1100LT Gunter
