CF
Here is the proper way to upgrade to relays. (Full size schematic is available on the download page)
Yes thanks for that, I actually took a look at and printed that off a few weeks ago.
Still finding my way around the bike and not really wanting to take off the fuel tank again for whats probably the 2000th time I didn't know where the wires actually came out, so I figured to do it the way I saw was the easy way (for me).
I simply just fed a relay coil across each feed from the Hi/Low connectors off the headlamp connector and switched a feed direct from the battery via a suitably rated fused cable. It does work and its very simple with just two SPST relays. However I ended up as I said with a slightly dim dipped beam, but hi beam was fine.
would guess it`s a problem with the low beam relay power feed wiring and/or related connectors.
My exact analogy INGE, except I swapped the relays over, and then swapped them out TWICE, they are fed via a very stout cable and the earthing is good. So it has me scratching my head right now. Unless of course I have a bad batch of relays..maybe
I'm starting to think I should maybe have just gone for a single headlamp unit now
To isolate the problem I would measured the voltage at relay power input, output and bulb connector.....with low beam on.
I cant remember now what the results where, but I'm sure I did that. Its a little too cold to work on it right now to pick it up again, but soon as we have a break in the weather I'll have another go at it. But for sure this is a no brainer, something so simple I'll probably kick myself when I find what it is. The lamps are H4 55W/60W in each headlamp. I did measure the current on low beam and IIRC it was around 6 amps, way too low for around 110W. Should have been more in the region of around 9 amps on low beam. Yet on high beam like a searchlight. Plug it in direct and its great...duh
But yes..........
get relays for those headlights mate .
You are quite correct Charlie
But thanks for reminding me of this, as I would have probably left this just plugged straight in.
Dave
