1 Seems a bit odd Sun Oct 28, 2012 1:43 am
Yesterday I wnnt to the Gatton Swap Meet and the dear old K wasn't running very well at low revs.
It was hard to start the day before and I put it down to not having been ridden or started for near 8 weeks.
It started fine yesterday and ran fine till I refueled about 10Ks from home and then when leaving the servo it started to run on 2 cylinders, I gave it a bit of a rev and clutched it down the road and as long as I kept it above 3200 it was OK.
On the highwat it was fine ran on all 4,didn't get hot or use heaps of fuel so I kept going and went to the swap meet.
Today I starts investigating and it is running on 3 cyl with #2 the odd one so I think fuel and injector. Pull all the plastic of and remove fuel rail and clean all the injectors but none were really blocked but #2 didnt have a good spray patern but not bad enough to cause big problems.
I removed the plugs and #2 was clean and the others black sooty from idling. so I thinks #2 not firing but why is #3 firing if #2 isn't.
Maybe leads or coil so I check them and they show all leads at 5.9meg and coils around 13meg so thats OK and then sitting there and wondering I pick up the #2 plug and measure the resistance, it's 11.6 ohms and the others are .3 ohms which on my meter is actually zero so I measure the #2 again and try scratching for clean metal and 11.5 was the best reading.
Thats as far as I have got so far as my old aching bones said quit now you silly old bugger or you will pay so I came inside and had some food and coffee and sat here to see what was happening in the K world and write this odd story so far. Will have to wait till tomorrow as where I live even the auto shop is closed Sunday. ( the thinking being horses and buggys dont need spark plugs so they dont open on Sunday).
So far I am thinking maybe a weak spark combined with a bad plug but suggestions from anyone will be considered.
