ianburgess
ianburgess
I have been trying to get my tacho, neutral light and gear selected indicator to work, have been using deoxy stuff on connectors etc, and decided to lift the rear of the fuel tank to see if any were hiding there.
I found a white cable coming in from the front of the fuse relay area going nowhere, a white round female plug connector with four wires into it (green & brown trace, red & yellow trace brown and a green & grey trace, and a white T female plug with a red & white trace and brown wire in it.
Any help will be appreciated.
Ian
Any idea where this cable and connectors go? Sam_0513
Any idea where this cable and connectors go? Sam_0515
Last edited by Crazy Frog on Sat Nov 03, 2012 5:58 pm; edited 3 times in total (Reason for editing : I can't get the photo's to work)
K100RT 05/87 vin 0094099K100RT Dark Blue (ex cop bike)
If I'm not mistaken...
"I found a white cable coming in from the front of the fuse relay area going nowhere"
It doesn't look factory, so the previous owner may have done some wiring.
"a white round female plug connector with four wires into it"
Probably the connector for the alarm system (anti-theft).
"white T female plug with a red & white trace and brown wire in it."
It's the connector for the power socket. See the bracket with a hole on
top of the coil cover? That's where the socket goes. Some places call it
a "merit" socket.
ReneZ
ReneZ
Fully agreed with the above. Don't recognise the round relay in the first photo, just in front of the white wire. Alternative from the original?
Rene
BMW K100 - 1985 (0030029) Scotland Any idea where this cable and connectors go? Rain
"Don't recognise the round relay in the first photo"
It may be a replacement indicator (flasher) relay.
ianburgess
ianburgess
blakey wrote:If I'm not mistaken...
a "merit" socket.
Thanks Blakey
It looks like I can ignore the first two items, but with the T shaped connector, should there be a male socket to connect to the female, and if so, any idea where I should start looking for that, or is for powering some ancillary equipment?
What exactly is a power (merit) socket?
Ian
Ian, a merit socket is an alternative (European) to the popular cigarette lighter socket. You can see them at a Jaycar store.
...and here (Moto-bins) you will see one. Search for 94900 and 94910.
I use the socket on my bike to attach a trickle charger.
Any idea where this cable and connectors go? Kontak12
About the round relay, since it`s a ex-police,
could be some remains from that..................
A ordinary flasher relay won`t function with the three switch system.
One day I'll have a good look at how to post a picture to the Forum...
Thanks Inge.
blakey wrote:One day I'll have a good look at how to post a picture to the Forum...
Any idea where this cable and connectors go? Queen110
Did read somewhere that you`re very fond of the queen of England,
so here you are.............................HINT, HINT, HINT.
You want me to dress up like the Queen?????
Oh...it's a link.
Whew, that was close...
blakey wrote:You want me to dress up like the Queen.
That would be a nice first posted picture.
ReneZ
ReneZ
Inge must be thinking of an Australian movie, something with queen (and dessert.........). Laughing
Rene
ianburgess
ianburgess
Thanks for the help people.
It looks like none of these will make my tacho work, so it's back to more research.
If I fit an aftermarket tacho, where would the best place be to attach a wire from it to a coil, assuming that's where it should go?
Ian
ReneZ
ReneZ
Where it is originally connected, on number one coil. Have a look at the wiring diagram?
Rene
ianburgess wrote:I have been trying to get my tacho, neutral light and gear selected indicator to work, have been using deoxy stuff on connectors etc,
About GPI and neutral light, have a look at this to check the connections.
About tacho, first check the black/blue wire running from the coil to pin #16 at the cluster....also check the cluster connector itself.
Then you could open the cluster and check the internal connections, not unusual it become a galvanic reaction between the clinched pins and the conductive film, due to different materials.
Any idea where this cable and connectors go? Tilkob10
Where your harness connects to the instruments it a good pace to check for continuity errors, also John deere have the merit plugs but I cant remember what they call them
17Back to top Go down   Any idea where this cable and connectors go? Empty wires Sat Nov 03, 2012 1:36 pm
nino
Help needed: anybody with scheme of instruments connectors (the green connector). I broke two wires in green comb, second and third from lower side(blue violet wire and green brown wire). Now I need some scheme to check what that wires connect (1984 early bike)
Thanks in advance
Pin 10: high temp. warning lamp (violet/black).
Pin 11: oil pressure warning lamp (brown/green).
Any idea where this cable and connectors go? Kontak13
nino
Thanks Inge I have to improvise something, little contacts broken too.
Contact: part # 61 13 1 459 104.
Any idea where this cable and connectors go? Kontak14
nino
Inge K. wrote:Contact: part # 61 13 1 459 104.
Do you have part number of plastic connector, please?
Sorry, don`t have any part number for the plastic housing.
I guess you have to buy a complete harness, used....if you need that one.
It`s Tyco that delivers the contacts.........you could try a search..........
