1Back to top Go down   No Power To Fuel Pump Empty No Power To Fuel Pump Mon Oct 15, 2012 6:37 pm
Motorandy123
Motorandy123
My bike is almost working after replacing the harness but I have a problem.
I don't have power going to the fuel pump. It looks like the ignition modual
isn't sending power to the fuel injection relay. I though at first it might not
be plugged in all the way (hard to get to under there). Any idea's? It could
have fried when the harness shorted. I'm having trouble getting it open. Is
there anything I can change inside? Thanks for any help!
MotoRandy123
1991 K75 "Special Edition"
2Back to top Go down   No Power To Fuel Pump Empty Re: No Power To Fuel Pump Mon Oct 15, 2012 6:58 pm
Do you got power to the FI relay coil?
Does your starter turn over?
Other symptoms occurring?
3Back to top Go down   No Power To Fuel Pump Empty Re: No Power To Fuel Pump Mon Oct 15, 2012 8:34 pm
Motorandy123
Motorandy123
Well everything else is working now. The starter works, but I disconnected it to check the
fuel pump power. The power is not getting to the coil on the fuel injection relay. It comes
directly from the injection computer. Not sure how to check it out?
MotoRandy123
4Back to top Go down   No Power To Fuel Pump Empty Re: No Power To Fuel Pump Mon Oct 15, 2012 8:37 pm
The power to the FI relay coil comes from the kill switch,
the ignition ECU grounds the coil.
The kill switch could also be the reason to your clutch switch problem, same source
Since the starter working, you got power to parts of the circuit that the kill switch feeds...so if you ain`t got power to the FI relay coil...the problem must be in the wiring.
The kill switch also feeds the coils......
5Back to top Go down   No Power To Fuel Pump Empty Re: No Power To Fuel Pump Tue Oct 16, 2012 9:08 am
Motorandy123
Motorandy123
Well I see the dash turn on and off with the kill switch so I believe that is OK. I didn't change the
switches on that side and found a loop back that was burned up. I fixed that but maybe one connection
is bad at that junction. Time to get the deoxit out. Thanks for the tip that the Ignition module supply's
ground!
MotoRandy123
6Back to top Go down   No Power To Fuel Pump Empty Re: No Power To Fuel Pump Tue Oct 16, 2012 11:46 am
Since you got power to the instruments, I suggest that you check the wires at the frontmost connector at fuse #1.
It should be two yellow/green wires, one coming from the kill switch, the other going to the FI relay coil.
The instruments is connected after the fuse.
