1Back to top Go down   power outlet k100 Empty power outlet k100 Tue Oct 16, 2012 4:49 pm
yankeeone
Hi, I want to add a power outlet on the dash of my 87 k100rt, there is on on the coil covers now, I would like to make only one connection to the battery, can I run them both to one fuse? what size fuse? or should I get a little fuse bar?
2Back to top Go down   power outlet k100 Empty Re: power outlet k100 Tue Oct 16, 2012 4:59 pm
yankeeone wrote:Hi, I want to add a power outlet on the dash of my 87 k100rt, there is on on the coil covers now, I would like to make only one connection to the battery, can I run them both to one fuse? what size fuse? or should I get a little fuse bar?
What do you want to run from the power outlet?
Unless you are running a compressor to inflate your tires, the fuse should be OK.
Just solder a set of wires to the original power outlet and pull them to the dash of the bike. The original outlet is already fuse protected.
power outlet k100 Frog15power outlet k100 Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   power outlet k100 Empty Re: power outlet k100 Tue Oct 16, 2012 5:05 pm
yankeeone
Thanks, I just want to run the GPS Though the fuse one the present one is the old ceramic type (like a Volvo)
4Back to top Go down   power outlet k100 Empty Re: power outlet k100 Tue Oct 16, 2012 9:49 pm
col
col
aerpro make a usbsocket that will give you the lower voltage you need evrey thing is built into it mine only cost me $20.00 aud you can use the usb cable i put mine inside the pocket of the fairing and can charge phone as well
1991 k100lt "the enterprise"
