1Back to top Go down   The K with no wheels Empty The K with no wheels Wed Sep 26, 2012 6:05 pm
Hover K100
Hover K100
While the other Irish were up in the wee north Very Happy I was out on a trip too.I know there isn't a pic of a K in this, there's not even a road but it is K power at its best cruising along at mid revs.Cornering is a little different too. Sorry about the shake, its from the V twin under the camera not the K in the back Very Happy
https://www.youtube.com/watch?v=cih7VGrGjeE&list=UUdSsRETBAowjOBxiKVMATag&index=1&feature=plcp
https://www.youtube.com/user/HoverIreland?feature=mhee
2Back to top Go down   The K with no wheels Empty Re: The K with no wheels Wed Sep 26, 2012 6:24 pm
Hover K100, The K with no wheels 112350
Why did you need recovering last year? Was it a K problem or something else?
3Back to top Go down   The K with no wheels Empty Re: The K with no wheels Wed Sep 26, 2012 6:49 pm
Hover K100
Hover K100
sidecar paul wrote:Hover K100, The K with no wheels 112350
er um er, Embarassed Embarassed
a rock jumped out from the river bank and hit me, since then I've discovered that by going a little slower it doesn't frighten them as much and they don't jump. A sequence of events led to a wet ECU so no fuel and a late night recovery., A replacement ECU along with some temporary repairs and we were running again the following day.
See at 1:45 on here
BTW the two larger craft are K100 powered.
https://www.youtube.com/watch?v=UzHIaHTqx5w&list=UUdSsRETBAowjOBxiKVMATag&index=10&feature=plcp
4Back to top Go down   The K with no wheels Empty Re: The K with no wheels Wed Sep 26, 2012 7:07 pm
[quote=.[/quote]
a rock jumped out from the river bank and hit me, since then I've discovered that by going a little slower it doesn't frighten them as much and they don't jump.[/quote]
The K with no wheels 44271 The K with no wheels 44271
5Back to top Go down   The K with no wheels Empty Re: The K with no wheels Wed Sep 26, 2012 7:10 pm
Nice vid HoverK. Looks very smooth any vids on which we can hear the machine?
The K with no wheels Ir-log1188....May contain nuts!The K with no wheels Ir-log11
K75RTP - 1994
6Back to top Go down   The K with no wheels Empty Re: The K with no wheels Thu Sep 27, 2012 5:07 am
88KE wrote:Nice vid HoverK. Looks very smooth any vids on which we can hear the machine?
and...
It would be nice if you could show us how the K engine is installed and how you propel the blades.
CF
The K with no wheels Frog15The K with no wheels Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
7Back to top Go down   The K with no wheels Empty Re: The K with no wheels Thu Sep 27, 2012 5:12 am
Yes, I'd like to see some details too!
8Back to top Go down   The K with no wheels Empty Re: The K with no wheels Thu Sep 27, 2012 3:55 pm
Thanks Hover, another good set of pics,
and +1 for more details.
Those rocks need a good talking to!The K with no wheels 167893
Cheers,
9Back to top Go down   The K with no wheels Empty Re: The K with no wheels Fri Sep 28, 2012 4:39 pm
Hover K100
Hover K100
Sidecar Paul, I did have some polite words with the rocks and it seems to have worked as they stayed put on the last trip Very Happy .
I have problems loading up pics onto this site, don't really know why. I'll try again later.
The 1986 K engine is mounted on rubber mounts on the floor of the craft, also one top mount, and is fitted with a centrifugal clutch, this allows the engine to start and tick over without the fan drive engaged. If it was a fixed drive the starter would have to swing the lot to start and any "kick" from the engine starting could break the drive belt. Next there is a short prop shaft with rubber donuts each end driving an oil filled bearing block fixed to the hull and from there drive is transmitted to the fan via 50mm wide toothed belt with approx 4:1 reduction. The fan is tuned to engine hp and allows the engine to rev to just below max revs. There is a Mini rad mounted in front of the main fan to provide cooling, A Mercedes fuel pump draws fuel from a low mounted tank through a suction filter and pumps through a standard BMW fuel filter. The wiring is simplified so that only three wires from the front are needed to run the engine, one to power up the ECU's, one to start it and a ground wire. This is my primary system, a separate loom is used for oil pressure, temp, fuel level etc. All electrics are mounted as high as possible under the engine cover.
88, the noise is a major topic of conversation on hover forums, however in the past few years major changes have taken place in fan design etc. The engine itself is relatively quite, silencing in via a collector 4 into one and into a silencer mounted on the hull. The original K one is considered too heavy to use.
My craft has a V twin 14hp Briggs to drive a lift fan and the noise from this is far more than noise from the K.
BTW the craft featured in a small article in the Sunday Times a couple of weeks back Very Happy
10Back to top Go down   The K with no wheels Empty Re: The K with no wheels Sat Sep 29, 2012 4:11 pm
Hover K100
Hover K100
The K with no wheels K_driv11
11Back to top Go down   The K with no wheels Empty Re: The K with no wheels Sat Sep 29, 2012 4:43 pm
Excellent work and great video too well done!
12Back to top Go down   The K with no wheels Empty Re: The K with no wheels Sun Sep 30, 2012 6:10 am
Hover K100
Hover K100
Sorry K=BIKE its not my work, the drive system is manufactured by K&M Products in the UK but I've done quite a few mods to it.
Here is the propshaft from clutch to bottom fan drive bearing. The clutch is contained in the K bellhousingThe K with no wheels K_driv12
13Back to top Go down   The K with no wheels Empty Re: The K with no wheels Sun Sep 30, 2012 10:27 am
BIG D
BIG D
Cool
Great stuff Hover k100, Take care and beware of suicidal rocks.
BIG D
14Back to top Go down   The K with no wheels Empty Re: The K with no wheels Sun Sep 30, 2012 3:51 pm
really interesting hover ....thanks for taking the time to show us a little more about this amazing craft
15Back to top Go down   The K with no wheels Empty Re: The K with no wheels Wed Oct 03, 2012 6:59 am
Björn
Björn
Stunning videos, thanks for sharing them! Hope to see you once we manage to get Dingle in to the schedule
In Thór's name we hit..... the road.
The K with no wheels R120011
