1 Cooling system issues Wed Sep 26, 2012 11:04 am
Dirk Digler
Following advice from pictures in this thread the relays are identified. One is labeled 'LSR' on that picture, can someone please tell me what that stands for?
I have a 1989 K100RS (with ABS removed) that blew off the bottom hose whilst looking for oil leak after rebuilding the water pump. The bike was idling for some 10-15 minutes when the bottom hose blew off the water pump. I now think almost for sure that this was my fault for not refilling the cooling system with the correct amount (2.8L) of coolant. I think now trying to remember what was in the container of coolant I drained off and then put back, it may have only been about 50% of what should have gone in (2.8L). For sure a very senior moment, and very costly it was too!
So I can work my way through this bike I am identifying all the relays. From the info in the previous thread, it says that the ABS relay is number three in the picture below, but can anyone identify what relay number 9 is in the big white socket at the bottom please? This is the picure of whats in my bike.
What I did last night on the advice of others in the intro thread
I removed the thermostat last night and heated it up on the stove in a pan of water with a digital thermometer in the pan.
Opening was around 86 deg and it was fully open around 95 deg so I think that its OK, it certainly cycled open/close when I cooled and reheated the water.
I measured the seal in the radiator cap, 25mm ID 36 mm OD so I think that is OK too. However, there was some crud in the cap and I dont know if this had anything to do with the valve in cap not opening. Here is a pic of the cap inside. I dont know if this would affect the safety valve in the cap opening or not. Anyone?
After cleaning that crud out, there was a nice clean white ring. The picture below also has the big sealing rubber ring removed for cleaning, I just didn't put it back yet.
The fan itself is OK as I put 12V on it on the connector at the fan. It runs fast and quiet.
So now I need to check the fan relay circuit.
I need to find out which number relay in the first pic of mine is the fan
I need to check the resistance cold and hot of the temperature sender.
If any of you whizes know what these relay numbers are and the sensor resistance - I'd appreciate it please? I will get there in the end but I'm trying to get this K100 up and running before winter sets in, and I have a long way to go yet.
I have not yet on all the accasions when the bike has been idling in the garage seen the cooling fan cut in. Lots of posts here relating to the fan cutting in but mine never has yet.
Cheers for any help
Dave
Cheers for any help
Dave
1989 K100RS, 1996 VFR750 FT, 2012 FJR1300
