1 K100 project final stages (?) Wed Oct 03, 2012 7:50 am
Hello to you all,
My saga goes on but draws to a close - I hope!
I had some electrical issues which are mostly sorted out.
The short circuit I had which was blowing fuse #2 (from top) has been resolved.
Brake light switches are both working and brake light is working.
Problem:
When the ignition is switched on the tail light comes on and stays on. In fact I tapped it and it came on and then stayed on in spite of moving the right handlebar light switch into different positions.
I am not sure if my bulb monitoring unit is working correctly. Could this be part of the problem?
Is it a faulty connection in the RH handlebar switch?
The wiring from the tail light to the bulb monitoring unit is good.
Any thoughts much appreciated.
Best
N
Problem:
Best
N
