1Back to top Go down   Changing fork oil Empty Changing fork oil Tue May 10, 2011 5:49 am
Richard1
I want to change the fork oil in my early 1985 K100RT. The Clymer manual shows a picture of the lower fork drain area. However my bike does not have the cap (as shown) on the left side. The cap shown appears to be the end of the axle on the right side.
It does however have a small hex head bolt on the back side (toward the rear of the bike) on each fork. Are these the drain plugs ?
Richard1
2Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue May 10, 2011 7:03 am
The 10mm cap screw on the back side of both fork legs are the drain plugs. There's a thin sealing washer on them so be careful to not lose 'em or replace 'em while you've got 'em off. The 'fill' plugs are the Allen head screws under a plastic caps on the tops of the fork legs. A large spanner is useful to hold and keep the fork 'inners' from spinning whilst you remove the plugs. Good luck with it!
3Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue May 10, 2011 9:02 am
Richard1
Thanks TWB. I don't know what I would do without all you folks out there. It's like having a machanic right here on my computer.
Richard1
4Back to top Go down   Changing fork oil Empty Changing fork oi Tue Aug 21, 2012 1:13 pm
I am about to change my fork oil, but one thing bothers me.How much mess is made when you undo the drain bolts?. Looks to me like the oil will just dribble down the bottom of the fork and go anywhere but into a container. Anyone had a mess free change?
5Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 1:20 pm
Embrace your inner Pig Pen, RT. Things is gunna get messy.
Changing fork oil Pigpen10
6Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 1:26 pm
quite the oil can be under a bit of pressure so hold a rag or your mother in laws nightie over the hole as you remove thr screw. and be careful as you pump the front end to get the remainder out.
be careful how tight you do the drain screws as they do strip easily.
GOOD LUCK 💣
7Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 1:38 pm
Aren't rags and mother-in-law's nightie the same thing?
More to the point, why on earth would anyone have access to said nightie Shocked shudder affraid
8Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 1:40 pm
This is a fork oil post, not a fork Oedipal post.
9Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 1:44 pm
Eggsackery. Personally, I would rather fork oil if I was given the option.
10Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 1:46 pm
pretty easy stuff rt ...
just prepare well for the oil flow ...a 2 litre ice cream container works ok ....but ....put down some cloths to catch the spilage ......dont forget to get the tops off first so it drains all smooth like ..instead of all that pumping from vacuume retension ....
in any case you will need to pump a little ..
what are you going to put in ol mate ?
somewhere between 5 and 10 weight is the go (i ended up using 7.5 for the first 200 ml and 10 for the last 160 ml .....360 ml total for ours ) .seems about right for me on the old rt
good luck !!
11Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 1:49 pm
charlie99 wrote:so it drains all smooth like ..instead of all that pumping from vacuum retension....
What viscosity is digested Ex Lax?
Now it's getting weird!
12Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 1:55 pm
probably waterish followed by mush ....giggles
13Back to top Go down   Changing fork oil Empty Changing fork oil Tue Aug 21, 2012 4:24 pm
Well I think somewhere in all that was my answer, you guys have upset me about my dear kind Mother in law ( did I mention my birthdays coming up soon?). I remind her every week and get a new $50.00, wonder how long I can carry this on for.
I am of course working on this thing in front of her unit (why mess up my own floor) but wanted to get a heads up.
Thanks to those who actually tried to help, and I was planning on mixing 5 n 10 weight oil to get a 7.5 but the
local bike shop said that was dangerous??. Do I need to put it in the mixmaster bowl to get a good mix?
14Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 5:06 pm
yes it can be dangerous. you may spill it on the floor and slip and end up like me.
you are safe doing it in an old tin can ans shaking like mad but putting it in the mix master is very dangerous. can i have your bike.
15Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 6:12 pm
I can see Rick has suffered badly from the fall.....but at least sense of humour is not affected. Question is, how would you feel if your mother in law drove off an 800 foot cliff on your K bike?
16Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 7:44 pm
I see that as a win win. My bike has insurance and MiL has life insurance which my wife would then inherit, which I would then plunder to put with the bike insurance to buy a new K. Win win.
I make the MiL comment as mine is here at the moment. About to have a 'procedure' tomorrow that has required her to clean her insides out (not inside out) IN MY BATHROOM.!!!!! Changing fork oil 314114
This procedure is a one day affair yet my wife thinks it totally reasonable that they come for four days?? They should go back to Bowral where they belong.
Maybe RT can put them up with his MiL? She will bring her own nighties Changing fork oil 652573
17Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 7:54 pm
now theres a thought 92 ...about 5 ks away from rt's place is exactly that....they call it "the maquarie pass" but im sure rt couldnt live with himself ,,,(besisdes they know where he lives and would just drag her back home ) giggles
tell your mates at the motor cycle shop to read the back of the castrol product rt .....which says you can mix this product with another grade to acheive the "weight " that you want ....!
not all products are compatible though, but usually in the same vendor product range, it is suitable
besides rick has a broken arm .....he couldnt possibly load your bike .....can i have it ?Very Happy
18Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 9:30 pm
RT two bricks and a 4litre icecream container will do the job easy. I put a wind up jack under the water housing to take the weight of the front so as to allow the oil to slowly drain into the container then lower it and the rest will come out then. the advantage of doing this work out front of the MIL's place is the stuff hanging on the line is just about the right size to clean up what ever you're doing. and the upside is she will enjoy shopping for more. Something we all hate. And to think they put this stuff at easy reach just when the hands are at their dirtiest. The darlings
19Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 10:04 pm
You guys are wicked Mad ....Poor RT and his MiL!
Keep your bike RT! ......can I have $50? Razz
Changing fork oil Ir-log1188....May contain nuts!Changing fork oil Ir-log11
K75RTP - 1994
20Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 21, 2012 11:07 pm
K75cster wrote:the advantage of doing this work out front of the MIL's place is the stuff hanging on the line is just about the right size to clean up what ever you're doing. and the upside is she will enjoy shopping for more.
RT, help Mil to keep the household budget low, then she got more bucks aside for your birthday.
A solution for a mess free fork oil change:
Changing fork oil Hpim0911
Changing fork oil Hpim0912
21Back to top Go down   Changing fork oil Empty Re: Changing fork oil Wed Aug 22, 2012 7:16 am
Just a sensible aside, I put a sheet of thick plastic under my bikes whenever I'm messing with oil.
It's easy to wipe clean when I knock the 'Inge mess free' container off it's wooden block. affraid
22Back to top Go down   Changing fork oil Empty Re: Changing fork oil Wed Aug 22, 2012 7:27 am
sidecar paul wrote: It's easy to wipe clean when I knock the 'Inge mess free' container off it's wooden block.
You got it the wrong way around, you must wait with the whisky to after the work is done.
23Back to top Go down   Changing fork oil Empty Re: Changing fork oil Wed Aug 22, 2012 7:46 am
Ahh, I live and learn.Changing fork oil 292303
24Back to top Go down   Changing fork oil Empty Changing fork oil Wed Aug 22, 2012 8:21 am
I knew I could rely on Inge for a proper solution. Thanks mate. I'll send MIL over for a few months in winter so you can have the money for a while.
Ok, one more short trip today then onto the job, got to buy some baby bottles I read about somewhere. Memory like a sieve at the moment.
25Back to top Go down   Changing fork oil Empty Re: Changing fork oil Wed Aug 22, 2012 8:56 am
good luck mate ....!
26Back to top Go down   Changing fork oil Empty Changing fork oil Wed Aug 22, 2012 4:16 pm
Dang, this was supposed to be easy. Forgive the blurred photos, that's pretty much how I see it these days.
Anyway, I removed the top Hex bolt from left hand fork
Changing fork oil Img_1110
Then I removed the bottom drain bolt (with patented cutout plastic bottle, sheets and newspaper in place)
Changing fork oil Img_1111
And viola, not the resultant mess I was expecting
Changing fork oil Img_1112
Nada,nix,zilch. affraid Can it be possible to even ride a bike without fork oil? I have pumped the thing up and down,
should I poke around in the drain hole, should I get drunk. All this and more perhaps.
What the McSquirt is going on?. Any similar stories out there, Please?.
I remain insanely your servant
27Back to top Go down   Changing fork oil Empty Changing fork oil Wed Aug 22, 2012 4:27 pm
No panic, as you were. I stuck an allen key in the drain hole and wiggled it a bit, and got what I was after. Man that stuff is as runny as water and looks like a sewer runoff. Think I should have done this a while ago.
Beer o'clock, have to settle the ulcer down
28Back to top Go down   Changing fork oil Empty Re: Changing fork oil Wed Aug 22, 2012 4:30 pm
Well it is possible but it certainly not very comfortable or safe.
That green goo looks like engine coolant RT.
Have you done the other one surely it has something in it besides air.
So all is now ok except for the smell.
29Back to top Go down   Changing fork oil Empty Changing fork oil Wed Aug 22, 2012 9:27 pm
Good spot Grasshopper
the patented container had coolant in it until I needed it for the draining.
I cannot believe that which has come forth from within the very bowels of the fork once even resembled oil.
It was just my very panicky being that forced my earlier post, but in the end seems to have worked out.
T Bone and wine and beers is the answer to all anxiety.
30Back to top Go down   Changing fork oil Empty Re: Changing fork oil Thu Aug 23, 2012 10:22 am
what happened bob ...back together ?
31Back to top Go down   Changing fork oil Empty Re: Changing fork oil Thu Aug 23, 2012 10:35 am
RT wrote:Good spot Grasshopper
Wow RT. Think I am coming to your place for dinner. Btw, do you just fix antiques or sell them from a shop?
I had a Robertson Pie Shop cherry pie for desert the other night.
The outlaws went to an antique shop in Robertson also. When I said I met a guy from Robertson who I thought did antiques, they said it sounded like the same guy.
I said I did not know if this guys sells them or just does them up.
They said it would have to be the same guy. Not a lot of people in Robertson.
So there you go RT.
So about that beer and T bone?
32Back to top Go down   Changing fork oil Empty Re: Changing fork oil Thu Aug 23, 2012 10:56 am
the pub sells a nice cooling beer rossco ...yes sir !
33Back to top Go down   Changing fork oil Empty Changing fork oil Thu Aug 23, 2012 1:32 pm
Patience Grasshopper. if I get it done in one day I'll have nothing to worry about overnight.
Both forks empty, trying to find a container with 360 mil measurement that doesn't come from the kitchen.
Correct weight Rossco, beer (Stella just for our Belgium friends) and a huge T bone, at a Scottish pub (must be, it had a tartan carpet) and I have a pair of shorts on today for the first time since May. A good sign but not a good look.
I only restore antiques, can't stand the general public, I'd rather hide away in my shed with my chemicals and listen to my home brew bubbling up.
Anyway this arvo should see it all come together, just in time for a massive storm front to move in. The old oil was disgusting.
34Back to top Go down   Changing fork oil Empty Changing fork oil Fri Aug 24, 2012 12:56 pm
Just in case anyone is the slightest bit interested, I managed to re oil the forks (quick trip into bike shop, needed 10mil more than was left in the bottle). I measured it all out perfectly but not too sure how much actually ended up down the tube, so when I get a chance for a test ride, if no oil pours out anywhere I will consider it a success.
Thanks for the guidance.
Last edited by RT on Fri Aug 24, 2012 12:57 pm; edited 1 time in total (Reason for editing : spellingk)
35Back to top Go down   Changing fork oil Empty Re: Changing fork oil Fri Aug 24, 2012 1:18 pm
[quote="RT" beer (Stella just for our Belgium friends). I'd rather hide away in my shed with my chemicals and listen to my home brew bubbling up. RT[/quote]
It's been said that Belgians, like Aussies with Foster's, only export Stella Artois to the rest of the world, but don't drink it much at home.
It takes like p*ss, but you can guzzle it.
Changing fork oil 22936
36Back to top Go down   Changing fork oil Empty Re: Changing fork oil Fri Aug 24, 2012 6:01 pm
aye !...nods head to that
my funky 6x year old boss thinls hes tremdy we drink his then head to the pub for real beer ...
37Back to top Go down   Changing fork oil Empty Re: Changing fork oil Fri Aug 24, 2012 9:22 pm
charlie99 wrote:aye !...nods head to that
Changing fork oil 44271 I can see it Changing fork oil 44271
K75RTP - 1994
38Back to top Go down   Changing fork oil Empty Re: Changing fork oil Sat Aug 25, 2012 6:27 pm
Well what ever the drink is it must have alcohol in it just look at that for a result
39Back to top Go down   Changing fork oil Empty Re: Changing fork oil Sun Aug 26, 2012 6:21 am
Given the old oil was nasty and sludgy which was why it didn't drain methinks it would be a good idea to go for a long run to really pump the oil around the forks and drain the oil out again and refill with fresh so as to be sure all the old nasty stuff is out of the forks and only clean oil is in there.
40Back to top Go down   Changing fork oil Empty Changing fork oil Sun Aug 26, 2012 9:01 am
I think I agree K Bike
went for a 100k run yesterday and am amazed how steady it felt on roundabouts and street corners. Need to
get a nice long run in. The old oil was more like water in consistency and the left hand fork was really full of grunge. I stuck a pipe cleaner in a few times to clear it out but as the oil change wasn't such a drama to do I will have to redo it soon.
41Back to top Go down   Changing fork oil Empty Re: Changing fork oil Sun Aug 26, 2012 9:45 am
onya bob! .....what did you end up using for measures and what weight did you use ?
42Back to top Go down   Changing fork oil Empty Changing fork oil Mon Aug 27, 2012 8:19 am
Charlie, as most pf my real miles are done with full panniers and packbag on the back, I decided to go with 10 weight at first. I'll do a run up to Oberon and check out the handling before deciding to change or not.
Well, the measuring system was a bit weird. I figured 360mil of water would weigh 360 grams, so put that much in an old squeeze mayonnaise bottle and marked it then put the oil in and attached some tubing to the
cone shaped open/close top, with gaffertape and proceeded to slowly squeeze the oil in. It mostly worked
except when I lost concentration and the tube briefly popped out of the filler. Then I made an uneducated guess how much I lost and replaced it.
Now I know there will be purists out there shaking their heads, but it feels fine and I will be flushing it again soon.
Huge frost and ice here today, no test rides this morning.
43Back to top Go down   Changing fork oil Empty Re: Changing fork oil Mon Aug 27, 2012 9:54 am
Just go to your local vet and get a 100ml syringe.
44Back to top Go down   Changing fork oil Empty Re: Changing fork oil Mon Aug 27, 2012 10:22 am
or a couple of babies bottles from woolies ....= under 3 bucks
but good thinking bob ...yay !
45Back to top Go down   Changing fork oil Empty Changing fork oil Tue Aug 28, 2012 8:59 am
This one is for anyone who thinks that their fork oil hasn't been done for a while.
I am not the most competent cornerer in the world as my fellow K travelers will tell you. Yesterday to test my work out I did 150 klm from my home, down Macquarie Pass, and south to Kiama and back up Jamberoo Road, two of the best bits of bike road you can find in a reasonably flat country. I found that I was at least one gear higher in all corners than normal, with extra speed and confidence that I am sure comes from both forks working together, with no drop off feel at all. I am really pleased (still got overtaken by a 285KW green Holden though).
Also came across an even older bloke than me riding a new BMW 1600 something, what a mean looking machine, he could hardly keep it upright at the lights, must've been a shorty (a rich one).
Last edited by RT on Tue Aug 28, 2012 9:00 am; edited 1 time in total (Reason for editing : Spelling)
46Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 28, 2012 9:55 am
Geez Bob, don't get too confident. I was looking forward to having someone to ride with at the back of the pack.
rossco
47Back to top Go down   Changing fork oil Empty Changing fork oil Tue Aug 28, 2012 1:13 pm
Nothing changes Rossco, I have to outlive my Mother in Law, and don't carry many spare undies so no super fast corners for me.
48Back to top Go down   Changing fork oil Empty Re: Changing fork oil Tue Aug 28, 2012 8:44 pm
col
col
i wont be long and you will be in front of me and rick rt
1991 k100lt "the enterprise"
49Back to top Go down   Changing fork oil Empty Re: Changing fork oil Mon Sep 24, 2012 1:00 pm
andyb
andyb
Just to bring this thread to life again, if anyone is putting off doing this, I just changed the fork oil on the weekend, along with new front pads. I'd been putting it off for ages and now I wished I hadn't. The difference in handling is night and day! It was the first time I'd done it, and I noticed only just around 300mls came out. With the correct 360mls (10wt) for the RT in, the suspension improvement is fantastic! And for the first time ever I dont have front brake squeel, thanks to a dab of the BMW disc paste on the back of the pads, Goodridge sports pads from Munich Motorcycles in Aus. Easy to do, got a oil mixing syringe from the local auto shop that came with a lenght of clear tubing so now access problems for 5 bucks which made it real easy. I reckon I'll let it slosh around and then drain again to get it nice and clean. definately worth the effort! cheers all
AndyB
'03 K1200GT,
'88 K100 RT
Chassis number: 0097248 ; Vehicle code: 0504; Series: K589
Model: K100RT 84 (0504 (0505) Body Type: K100RT 84 (0504)
Catalog Model: ECE; Engine: (0504); Production: 1988/9
Changing fork oil 13763011
