Guys
Yes it sucks and very very painful it is,
but my fault entirely for not filling the cooling system to the correct full amount, I hold my hands up. Reasonbly convinced now that is what caused the problem.
Inge K
About Blue Hylomar, I`m also quite fond of that one.....but at the
oilpump/sump joint it`s useless due to the oil pressure....tried a lot
of different...ended up with Permatex black RTV.
The anoying thing is I sent an email to Hylomar asking if it would be suitable as I was unsure and the reply came back as yes.
The second attempt was with ABRO black silicone sealant.
Seems to be OK, wont know for sure till I get the bike running again.
I do agree that the relief valve should have opened, and maybe it
did..but couldn`t cope with the volume through the small opening. When
water turn into steam things happens amazingly fast, and with a lot
more empty volume to build up the steam pressure...............But it could be a idea to pressure test the cap....should open at 1,0 bar +0,15.
Well the hissing noise when the bottom hose blew off was extremely loud, quite frightening really. So I gues your probably right there over the amount of pressure.
Lesson leanrned the hard way I'd say, I will be more carefull in future but as I get older the accident do seem to be more common duh!
Thanks very much for on how to test the fan. I know the fan works because I put 12V on the connector when I repaired and painted the radiator recently.
I have another question if I may ask?
This bike has the ABS removed, I know that for sure as there are no pumps on it, there is a fluid line bypass loop on the rear mudguard, there is a very large multiway connector hanging in the rear cowling, and there is also a relay missing in the big box under the seat where all the other relays are.
My question is this guys.
Is there a picture available of the relays in this box under the seat with what they are and the pin connections anywhere please? So I can carry out the suggestions re testing the relay. There are two big relays in that box. One has been removed, the one on the LH side when sitting on the bike. I'm guessing thats ABS but not sure.
Just waiting now a little for pain to drop somewhat so I can take a look, although the ear-ache I'm going to get from the wife the minute I set foot in the garage
will be far more painful!
That I am quite sure of Thanks again.
Dave
