1Back to top Go down   heated grip switch Empty heated grip switch Fri Sep 14, 2012 3:51 pm
jings
jings
can anyone tell me how many amps the heated grip switch on a k100 is rated as i want to change the switch
2Back to top Go down   heated grip switch Empty Re: heated grip switch Fri Sep 14, 2012 8:26 pm
Motorandy123
Motorandy123
I couldn't tell you exactly but most heated grips draw 30 - 40 watts which
is 3 - 4 amps. It is common to spec a switch with double the power so 6
to 8 amp. But switches are usually sold in 5 amp increments so I'd guess
a 10 amp switch is in there.
3Back to top Go down   heated grip switch Empty Re: heated grip switch Sat Sep 15, 2012 12:48 am
10 amps will see you right with that one
4Back to top Go down   heated grip switch Empty Re: heated grip switch Sat Sep 15, 2012 1:24 am
The OEM grips have a rather low power consumption, 2,1 amp at the high setting.
So a 10 amp switch isn`t really needed, but better safe than sorry
(especially if the word China appears on the switch).
5Back to top Go down   heated grip switch Empty Re: heated grip switch Sat Sep 15, 2012 5:43 pm
jings
jings
thanks for the help
6Back to top Go down   heated grip switch Empty Re: heated grip switch Sat Sep 15, 2012 7:21 pm
I discovered yesterday that although I do not have heated grips the bike is wired for them, has a switch etc. Is it an easy job to fit heated grips as in must they be BMW or will any type do?
92KK
7Back to top Go down   heated grip switch Empty Re: heated grip switch Sat Sep 15, 2012 7:41 pm
The easiest (and most expensive) is to get the OEM grips, as it`s just plug and play.
Strange that you have both all wiring and switch and no heated grips.
Could it be that they just don`t function, they don`t last forever.
If you got them the LHS grip is fixed with screws on the inner end, otherwise it`s glued.
If I remember correctly, heated grips was standard on the LT
(but don`t know if it`s was like that on all markets).
