1Back to top Go down   Loose fitting belly pan assembly Empty Loose fitting belly pan assembly Mon Sep 10, 2012 2:58 pm
UK_Kev
UK_Kev
Do any of you have, or can point me to a diagram of the belly pan assembly, my one is loose, even though some of the bolts are tight, I would like to see what should be there and where, if possible.
http://backstreetthunder.wordpress.com/
1954 - Norton (Manx) Project - 1974 Z1b - 1983 R80ST - 1991 K100RS - 1993 Enfield Bullet
2Back to top Go down   Loose fitting belly pan assembly Empty Re: Loose fitting belly pan assembly Mon Sep 10, 2012 4:26 pm
I would guess your problem is worn grommets at the RHS bracket to oil pan mounts.
It`s two threaded pins in the oil pan which go through two rubber grommets in the bracket.
Loose fitting belly pan assembly Spoile10
3Back to top Go down   Loose fitting belly pan assembly Empty Re: Loose fitting belly pan assembly Mon Sep 10, 2012 4:38 pm
UK_Kev
UK_Kev
Thank you, I shall take it apart and see what's missing, but it seems to be loose at the rear on the left side, that vertical bolt arrangement maybe?
4Back to top Go down   Loose fitting belly pan assembly Empty Re: Loose fitting belly pan assembly Mon Sep 10, 2012 5:05 pm
UK_Kev wrote:but it seems to be loose at the rear on the left side, that vertical bolt arrangement maybe?
Looks like a very correct conclusion.
