1 No dash lights / won't start Mon Aug 20, 2012 4:31 pm
tdkclydes
Hello , I am having some trouble chasing down a electrical problem . I get no lights on the instrument panel , also no brake lights turn signals or horn . The tail running light comes on and the small light at the top of the headlight . On the top fuse I have no power , also no power on the bottom 2 fuses . At the ignition switch I have power on the red and gray wires but nothing on the gray/ blue stripped or the green . I had every thing working and the bike running . The work I have done just prior to the problem was 1) lubed the rear drive shaft splines . 2) replaced the brake light bulb , 3) installes a new battery 4) I had the headlight bulb connector off to check the type of bulb ( looking at installing a relay and modulator ) . Could the neutral switch be holding things out ?
Thank you Tom
Thank you Tom
