1Back to top Go down   Gear/ Brake lever swap Empty Gear/ Brake lever swap Tue Aug 14, 2012 9:13 am
gmcq
gmcq
Hi all, great site. Hoping for suggestions. Is it possible to swap the gear change to the right and brake to the left? Screwed together left ankle giving a bit of jip.
Also, gear oil leaking out around the gear lever, is this a big operation to fix?
2Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Tue Aug 14, 2012 10:03 am
The leaking oil should be easy by diging the seal out and then putting one back in making sure not to get too rough.
I have done a few bikes over the years for people with prosthetic leg etc.
You could use the master cylinder and extend the hydraulic line, you would need to make a lever as you couldn't move the brake lever to the right side.
The gear lever can be done by some linkages similar to what rearsets have and a shaft across the frame probably above the gearbox and infront of the battery.
Anything can be done but is it worth the time and or money.
3Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Tue Aug 14, 2012 4:48 pm
gmcq
gmcq
Thanks Rick
As you say, is it worth it. Think I will just put both feet down when I stop - cheaper!
4Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Tue Aug 14, 2012 5:27 pm
I'd look at a lot of modifications before starting down the road of designing one for yourself gmcq. That's "doable" but not as easy as it might first look.
Pop over to the new members section and stick up an intro about yourself and the bike, as is the custom here (and also necessary for access to the downloads section which you'll need.)
Welcome along!
88KE
Gear/ Brake lever swap Ir-log1188....May contain nuts!Gear/ Brake lever swap Ir-log11
K75RTP - 1994
5Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Tue Aug 14, 2012 5:45 pm
Hi gmcq,
These things can be done. It's not much help to a K owner but when I bought my first BMW, an '78 80/7, all my bikes were 'british' format so I made linkages to swap over the gearchange lever and brake lever to the PROPER side. The parts are still in the shed.
Cheers,
Paul
PS I'm ambipedal now:D
Last edited by sidecar paul on Tue Aug 14, 2012 5:48 pm; edited 1 time in total (Reason for editing : PS added)
6Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Wed Aug 15, 2012 9:02 am
gmcq
gmcq
Guys,
This idea of mine, is it legal?
G
7Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Wed Aug 15, 2012 12:59 pm
Legality varies from country to country and you'd have to get your question answered by someone familiar with Irish road regulations. Your best bet is to contact the Department of Transportation and make an inquiry.
8Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Fri Aug 17, 2012 8:13 am
with regard to the rules on gearlever placement and brake placement. if your very fine island has left hand braked nortons and bsa's then you should be able to follow suit as you would be using a footpeg mount that is not a unit part of the frame and so should be exchangeable to your prefferences
9Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Fri Aug 17, 2012 9:17 am
gmcq
gmcq
Robmack/ K75cster,
Thanks for the advice. Will do more research and not something I will be doing in the near future, going to be an expensive modification.
G
10Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Fri Aug 17, 2012 6:13 pm
Comberjohn
Comberjohn
Regarding the legality of such a mod.
I would imagine that if it gets a pass from our government run MOT centres, it should be OK.
The MOT centre might be a good place to start any enquiries about it anyway.
On a similar note, I spotted a guy on one of the new Norton Commandos in Newcastle a few weeks ago. I was told he lost an arm, right one I think, and all the controls were now on the left bar.
Hard to imagine how you would adapt to that.
Maybe meet you next month at the Autumn run, gmcq. I'm not too far from you if you ever need a hand with the K.
11Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Sun Aug 19, 2012 10:46 am
gmcq
gmcq
ComberJohn,
Thanks for the offer. The K is getting collected tomorrow by Mototec of Ballinderry, Lisburn to sort out all the probs with leaks etc, early birthday present from my wife. MOT next so hopefully I can make the next meet. Looking forward to it.
G
12Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Sun Aug 19, 2012 10:57 am
twincarb
twincarb
As long as you have the controls on the bike and they work then it is considered road legal. There is no specification stating that things have to be where they are "normally found"...
It's just that all bike and car manufactures copy cat the positions as thats where we are used to them being... just think in a car the headlight switch's are often found in different locations depending on the make and model
Yamaha Thundercat
Gear/ Brake lever swap 169042Gear/ Brake lever swap 169034
13Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Sun Aug 19, 2012 1:14 pm
gmcq
gmcq
Twincarb,
Thanks for the advise.
G
14Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Sun Aug 19, 2012 7:44 pm
yep makes it all interesting ...once had a duke (left hand brake pedal ) and a yammi on the farm (right hand brake pedal ) always knew when i couldnt change gear ...to think a little more about it ...after a while no issue at all
there will be a way to do it gmcq ...good luck
15Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Mon Feb 10, 2014 5:58 pm
bushyintas
bushyintas
I know its been a few months but this is your answer.
https://www.k100-forum.com/t7499-for-sale-kliktronic-push-button-gearchanger#86481
Gear/ Brake lever swap 110
regards Bushy
Bushy
k100 RT 1988 #0095723
K100 RT 1984 into Custom Single seat.  #0024503
16Back to top Go down   Gear/ Brake lever swap Empty Re: Gear/ Brake lever swap Mon Feb 10, 2014 7:04 pm
Yeah I have seen them used, they are very effective at bending selector forks.
