1 Output shaft removed today Mon Aug 06, 2012 8:55 pm
paul.dickson_VA
Output shaft - https://i.servimg.com/u/f34/17/64/54/93/output13.jpg
Removed the output shaft today - surprised to find that none of the rivets appeared to be loose whatsoever.
Engine block with output shaft removed - https://servimg.com/view/17645493/22
Once the clutch housing and bottom crankcase were removed the shaft came right out. The bearing (behind he output shaft gear turned with no binding - looked very good.
My primary bike - 2002 K1200LT - https://servimg.com/view/17645493/21\
This is the bike I have been riding for the past several years - only has 7K miles on it. I am working onthe K100 in order to have a sportier bike.
A couple questions that I am looking for some thoughts:
1. Although the output shaft rivets seemed nice and tight - I am curious if it still makes sense to swap it out for a 12-rivet shaft? I am doing everything that I can think of to avoid having to break open the engine any time soon - thoughts? Anyone know what a reasonable price is for a 12-rivet shaft?
2. I was advised by a BMW service department that I should perform an upgrade on the water pump - he says that a new impeller and associated parts should be replaced if still original in my 85 - looks original. The impeller looks more like a reversed impeller - he says that the replacement looks more like a fan blade - any thoughts if this should be replaced while I have the water pump open?
3. Lastly - I think I heard someone say that the output shaft isn't hollow all the way though - still trying to pull the pilot bearing out and wold be much easier if I could push it out from the other end - can someone confirm if it does/does not go straight through (shaft).
