Number of posts : 1589
Giles,
Whilst searching for something else, I came across an old faulty gear position switch. The fault is in the encapsulated wiring at the top of the switch but the lower part, springs and pins are OK.
I've cleaned the spring sockets and pins, DeoxIT of course, and it's showing good contact between the pins and the central earth contact.
If you want it PM your address and I'll put it in the post.
To test the assembled switch, here is the switching logic:-
There are 4 wires,
A.....yellow/blue
B.....yellow/black
C.....yellow/white
E.....brown (earth)
1st...............B C... connected to E
Neutral.......A B C... to E
2nd............A... C... to E
3rd...................C... to E
4th............A B...... to E
5th...............B...... to E
