1Back to top Go down   Right Handle Bar Assembly Empty Right Handle Bar Assembly Thu Jun 28, 2012 12:44 am
fearlesspk
Hey Everyone,
I need a new right handle bar assembly for my 92 k100rs. I searched all online for a used one but can only find it new direct from a BMW dealer. The part number is
32 72 2 352 165 HANDLE UNIT, RIGHT - D=20MM
Does anyone happen to know where I can get for for a decent price or an alternative? Brand new it is $417.22 USD.
2Back to top Go down   Right Handle Bar Assembly Empty Re: Right Handle Bar Assembly Thu Jun 28, 2012 11:23 am
cruise_carter
cruise_carter
http://www.motobins.co.uk/index.php
Motobins in the UK ships quickly and at a nice price to North America.
I have ordered several things from Motobins with zero issues.
Royal Mail got parcels to me in under 2 weeks.
Contact them and get a price.
Dale
Currently on the hunt for another old K bike (K100RS would be perfect)
2004 R1200CLC (gone recently......those evo brakes are brutal)
1985 K100RT, lots of km but lots of life left (gone)
2002 HD Electra Glide Classic (gone)
1987 K100RS (gone)
2002 HD Road Glide (gone)
2000 R1100R (gone)
lots more in the past........
3Back to top Go down   Right Handle Bar Assembly Empty Re: Right Handle Bar Assembly Thu Jun 28, 2012 11:40 am
nino
On www.motorworks.co.uk you can find all used parts. Check availability with them. What is with your right end? Is it broken? If the brake cylinder was problem I think is possible to repair in some workshop like one here in my neighbourhood. They usually clean and mount new O rings. Its not expencive like new or used part?
Regards
4Back to top Go down   Right Handle Bar Assembly Empty Re: Right Handle Bar Assembly Thu Jun 28, 2012 1:04 pm
Apaprently motorworks dont ship to US for some reason.
I have used them and would also recommend them but you might need to order to a uk delivery address and have it mailed on to you from there. It is double handling but anything I have got has been well priced and well packaged.
5Back to top Go down   Right Handle Bar Assembly Empty Re: Right Handle Bar Assembly Thu Jun 28, 2012 2:31 pm
fearlesspk
On motorworks I found Used - Brake master cylinder and res front ( K series not 16 valve ) | BRK10786 Do you happen to know if that is the same thing I am looking for, and would it work for the 92 k100rs? I wish there was a picture.
6Back to top Go down   Right Handle Bar Assembly Empty Re: Right Handle Bar Assembly Thu Jun 28, 2012 3:42 pm
nino
fearlesspk wrote:On motorworks I found Used - Brake master cylinder and res front ( K series not 16 valve ) | BRK10786 Do you happen to know if that is the same thing I am looking for, and would it work for the 92 k100rs? I wish there was a picture.
Ask for 16 V right bar end its different then 8 v. Send them an email. They have a lot of broken bikes. What do you need, if it is brake cylinder 16 v you can order new one, but also service kit, piston with O ring (much cheaper)
7Back to top Go down   Right Handle Bar Assembly Empty Re: Right Handle Bar Assembly Thu Jun 28, 2012 8:07 pm
The 2V and 4V front master is quite different, one thing is the piston/bore.........and to use a 2V master on a 4V you need to change some more things than just the master.
(housing,lever, twistgrip, cable..........)
