1Back to top Go down   Tip of the day.... Empty Tip of the day.... Mon Jul 02, 2012 4:03 pm
Just found a simple solution to check the fuel pressure regulator (FPR).
No need to buy a very expensive set of gauge cheers
Just get one of these Bicycle pump with a built in gauge ($13.00). They are capable of pushing up to 120psi and you just have to monitor the gauge to find the setup of your FPR.
Just unplug the return line from the fuel rail, attach the pump to the hose (may need to make an adaptor) and start pumping.
Tip of the day.... Bicycl10
available here
Tip of the day.... Frog15Tip of the day.... Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
