51 Re: Engine cutout Sat Sep 08, 2012 6:03 pm
just extend your fuel lines a little , you should be able to run the bike with the tank suported a bit above the frame to gain access with the pump connector outside the frame .
with out all this on off stuff.....till you get it solved at least ....you can buy cheep fuel line for this purpose as we're not going to use it forever ,,just make sure the high presure line seals up well , actually i have a butterfly type hose clamp thumb twist on my high presure side ..for easy removal ..just havent installed one on the return line yet ...(put it on the list i guess )
there may be some interaction between the relay load and the resistance measurement ...so may be an idea to check the terminal on the connector side to earth after a run up to temp
