1Back to top Go down   Needle bearing removal Empty Needle bearing removal Fri Jun 29, 2012 3:09 am
BooG
BooG
Any other ideas for needle bearing removal from actuation arm?
Don't have access to a slide puller. Haven't got a diamond coated file, but could get one as this looks reasonably easy....Screwdriver and hammer, with WD40 and heat, applied from my soldering torch?
2Back to top Go down   Needle bearing removal Empty Re: Needle bearing removal Fri Jun 29, 2012 5:46 am
Heat is a good starting point but dont go too hot ( not past 160deg C) or you start to affect the tensile strength of the aluminium.
3Back to top Go down   Needle bearing removal Empty Re: Needle bearing removal Fri Jun 29, 2012 6:26 am
And rather use a pin punch, than a screw driver.
Less possibility of unwanted marks inside the actuator arm.
4Back to top Go down   Needle bearing removal Empty Re: Needle bearing removal Fri Jun 29, 2012 1:11 pm
walfish
walfish
Use a masonary anchor(Rawl Bolt) , If I remember correctly it is one of CF's ideas. Needle bearing removal 212902
Needle bearing removal Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
5Back to top Go down   Needle bearing removal Empty Needle bearing removal Fri Jun 29, 2012 7:46 pm
Or do what I did and give the whole arm to an engineering shop and walk away for a day. But then I'm pretty
lazy.
6Back to top Go down   Needle bearing removal Empty Re: Needle bearing removal Sat Jun 30, 2012 4:37 pm
BooG
BooG
How does the masonry anchor bolt thing work?
7Back to top Go down   Needle bearing removal Empty Re: Needle bearing removal Sat Jun 30, 2012 7:57 pm
Never tested this metod, but I think the idea is to use a bolt with a expanding metal sleeve.
And fit the bolt so it is just past the bearing at the inner end,as the sleeve expands conical at the end it locks at the end of the bearing.
And then hit the end of the with a pin punch from the other side...........
Or, if it`s enough threads....pull the bearing out, with the aid of some various lenght bushings and washers.
Another thing is to find a suited bolt , with this small diameter.........but with some search.
8Back to top Go down   Needle bearing removal Empty Re: Needle bearing removal Sun Jul 01, 2012 8:00 am
BooG
BooG
Been trying with some needle files (non-diamond)...don't seem to make that much of an impression....
9Back to top Go down   Needle bearing removal Empty Re: Needle bearing removal Sun Jul 01, 2012 8:31 am
And have you lost your hammer and pin punch....?
10Back to top Go down   Needle bearing removal Empty Re: Needle bearing removal Sun Jul 01, 2012 10:43 am
6mm stainless rod would get that out, put it out in the sun and get it warm will help.
