1Back to top Go down   Ratchet noise when driving off? Empty Ratchet noise when driving off? Wed Jun 27, 2012 6:46 am
Suicidalbadger
Suicidalbadger
Bike is great when running but initially when driving off after starting its like something is loose or not engaging properly? otherwise bike goes great...Bike is new to me had it a few weeks it's done 56,000miles and was a police bike, so I hope it was well maintained in its past life.
Any ideas or is this normal K noise, its the first shafty I've had so I guess the transmission noises will be different. I'm happy to dismantle and fix anything having rebuilt a few bikes from the frame up.
Thanks for any help
2Back to top Go down   Ratchet noise when driving off? Empty Re: Ratchet noise when driving off? Wed Jun 27, 2012 10:12 am
Welcome Suicidalbadger. Slide on over to the members intr and say hello, as is the custom and practice on here. you need to do that anyway in order to get access to the technical stuff in the downloads section.
I get a bit of rachet noise too. I always put it down to the clutch. How severe is it?
88KE
Ratchet noise when driving off? Ir-log1188....May contain nuts!Ratchet noise when driving off? Ir-log11
K75RTP - 1994
3Back to top Go down   Ratchet noise when driving off? Empty Re: Ratchet noise when driving off? Wed Jun 27, 2012 10:20 am
Suicidalbadger
Suicidalbadger
Thanks 88KE, not severe just unusual, almost made me think I was dragging centre stand as it just goes away after half a turn of the wheel.
I also thought clutch but again a noise I'm not used to on other machines.
4Back to top Go down   Ratchet noise when driving off? Empty Re: Ratchet noise when driving off? Wed Jun 27, 2012 12:19 pm
there is a damper in the final drive before the clutch and a spring loaded device on the input shaft of the gearbox .....i too notice that noise , but figure it to be the damping mechanisms comming into effect on that initial torque off the mark..
hope that helps...it seems pretty common
5Back to top Go down   Ratchet noise when driving off? Empty Re: Ratchet noise when driving off? Wed Jun 27, 2012 2:26 pm
nino
Yes Charlie I have same noise but only with cold engine. After warming up it disapear...
6Back to top Go down   Ratchet noise when driving off? Empty Re: Ratchet noise when driving off? Wed Jun 27, 2012 4:54 pm
Fifth Horseman
If it only happens pulling away the first time after starting the engine, it is probably the ABS doing its self test - a good clue is the ABS warning lights going out as this happens. The self test also seems to repeat at intervals when pulling away from a halt.
My ex-police K11 also exhibits this behaviour.
7Back to top Go down   Ratchet noise when driving off? Empty Re: Ratchet noise when driving off? Wed Jun 27, 2012 9:19 pm
My K1100 does much the same thing only when its cold, I figure it's a bit of chatter in the drive line and besides aren't we all allowed to shiver a bit when we are cold.
8Back to top Go down   Ratchet noise when driving off? Empty Thanks problem solved or explained Thu Jun 28, 2012 3:35 am
Suicidalbadger
Suicidalbadger
Great, thanks for the replies, hearing that other people have the same noise from cold and that it's probably the ABS will stop me worrying as we head off for a 2500 mile trip soon...oil change today and we're ready to go. These bikes are quite impressive at eating the miles in (for bikes) comfort.
9Back to top Go down   Ratchet noise when driving off? Empty Re: Ratchet noise when driving off? Thu Jun 28, 2012 3:56 am
aye your right there mr badger .....a few of us did somewhere around 3000 ks in under 3 days ...not that long ago now
