1Back to top Go down   instruments vibrating Empty instruments vibrating Wed Jun 27, 2012 8:31 am
ali2908
ali2908
Finally got to ride the bike today 1985 K100 RS but the instruments are vibrating, there is a metal plate mounted to the handlebar mount which appears to have sticky tape residue or old foam. should this be attached to the instruments looked at the Haynes and Clymer manuals nothing conclusive there.
https://servimg.com/view/17507255/13
Again any help appreciated
Ali
2Back to top Go down   instruments vibrating Empty Re: instruments vibrating Wed Jun 27, 2012 8:41 am
Check the rubber mountings,,,or do you got to much vibs in the front end?
instruments vibrating Instru10
3Back to top Go down   instruments vibrating Empty Re: instruments vibrating Wed Jun 27, 2012 8:42 am
Hi ali,
Your plate is fitted the wrong way round.
The side that has foam on it (the foam shouldn't be there) should be against the handlebar pad.
4Back to top Go down   instruments vibrating Empty Re: instruments vibrating Wed Jun 27, 2012 8:48 am
ali2908
ali2908
Paul do you mean that the foam part should be under the instruments?
5Back to top Go down   instruments vibrating Empty Re: instruments vibrating Wed Jun 27, 2012 8:51 am
ali2908
ali2908
Inge not sure about the vibration only got it to about 30 MPH first time on a bike for 20 years so was taking it easy in our work car park.
Ali
6Back to top Go down   instruments vibrating Empty Re: instruments vibrating Wed Jun 27, 2012 8:57 am
ali,
Take the plate out, turn it through 180* and put it back.
You'll find that you then have clearance for the cluster to float on it's rubbers and absorb any vibrations.
7Back to top Go down   instruments vibrating Empty Re: instruments vibrating Wed Jun 27, 2012 8:58 am
ali2908
ali2908
Ok i'll try that tomorrow
Ali
8Back to top Go down   instruments vibrating Empty Re: instruments vibrating Wed Jun 27, 2012 11:45 pm
ali2908
ali2908
That fixed it thanks
Ali
9Back to top Go down   instruments vibrating Empty Re: instruments vibrating Thu Jun 28, 2012 12:03 am
Good going Ali. take it easy on that machine until you get a few hundred miles under your wheels, or better still book a couple of lessons with a pro to get you back with good habits. I did after a 16yr absence and it was well worth the time and small expense.
88KE
instruments vibrating Ir-log1188....May contain nuts!instruments vibrating Ir-log11
K75RTP - 1994
10Back to top Go down   instruments vibrating Empty Re: instruments vibrating Thu Jun 28, 2012 3:10 am
ali2908
ali2908
Good advice, I was thinking about doing that.
Ali
11Back to top Go down   instruments vibrating Empty Re: instruments vibrating Thu Jun 28, 2012 5:34 am
Good result Ali,
K problems are sometimes silly little things that are not immediately obvious.
Enjoy your bike,
