1 RS 4 Valve (1991) Coil resistance Wed Jun 27, 2012 4:01 pm
giles4060
Hi all,
Experiencing stuttering under load when bike is warm (again). Last time it did this it burnt out the main wiring loom and a replacment loom (second hand) and Voltage regulator (new part) sorted it out. Now 3000 miles on it is doing it again.
Hoping someone may be able to help me understand the resistance readings from my coils.
Coil 1 = 14.51 K Ohms / 1.4 ohms
Coil 2 = 14.36K Ohms / 1.4 ohms
I understand the resistance on 2 valves should be 12.6 KOhms / 2.6 Ohms. I an not sure if resistance is different for the four valve and sure was these readings mean anyway? How likely would it be that both coils would be deterating at the same rate? Or could this indicate a dodgy reading from a not overly expensive multi meter?
I have no reason to believe these are not original coils and the bike has now done 77k miles.
Grateful for any advice. Every days a school day with a K.
