1Back to top Go down   new k100 owner in Oregon Empty new k100 owner in Oregon Sun Jun 24, 2012 9:47 pm
scout18
scout18
Greetings to the list, I just bought a k100rs. I'm charging the battery now and expect it to fire right up. There is one issue however. The shift lever is kind of floppy like it has a broken spring. It cycles the gears it just doesn't return to a normal middle position by itself.
2Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Sun Jun 24, 2012 9:57 pm
Welcome Scout!
You have found the correct place to be a member as a owner of a old K.
Plenty of info, and not to forget all the helpful lads.
Sorry to dissapoint you, but it sounds like you got a loose grub screw at the other end of the shaft.
3Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Sun Jun 24, 2012 10:28 pm
scout18
scout18
No worries I'm pretty mechanical. I'm trying to run down a manual for it.
4Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Sun Jun 24, 2012 10:34 pm
Thanks to our member Zonenfeile, this is possible here.
5Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Mon Jun 25, 2012 1:23 am
scout18
scout18
What a wonderful resource. I know exactly which screw it is now. It looks like the tranny needs to come out to get at it but that's alright. I probably want to have a look in there anyway.
6Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Mon Jun 25, 2012 8:40 am
Welcome Scout - I see you've already discovered what a resource the forum is!
We love to see pics of members bikes too.
88KE
Last edited by 88KE on Wed Jun 27, 2012 4:53 pm; edited 1 time in total (Reason for editing : spelling)
new k100 owner in Oregon Ir-log1188....May contain nuts!new k100 owner in Oregon Ir-log11
K75RTP - 1994
7Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Mon Jun 25, 2012 12:43 pm
scout18
scout18
So does the transmission have to come out to tighten the grub screw on the shifter shaft? No secret BMW trick to do this in situ?
8Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Mon Jun 25, 2012 1:12 pm
Beside drilling a big enough hole in the gearbox housing,
there is not any known shortcuts to get acces to this grub screw.
9Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Mon Jun 25, 2012 1:30 pm
scout18
scout18
Very Happy Thanks Inge. I guess I'll get to it then.
10Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Tue Jun 26, 2012 7:25 pm
scout18
scout18
Ok is it really necessary to pull all the final drive stuff to get at the grub screw. Can I leave it attached to the gear box? It seems like it can all stay together.
11Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Tue Jun 26, 2012 7:37 pm
It is possible to remove gearbox/drive assy as one unit.
Take care with the clutch pushrod........or drain the gearbox and remove it.......
before dismantling.
12Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Tue Jun 26, 2012 7:48 pm
Could maybe be a idea to put your questions in the technical section........................
Someone later searching gearbox repair info...wouldn`t find it logical to search for this in the Member`s introduction section....................
13Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Tue Jun 26, 2012 9:11 pm
scout18
scout18
Of course I will do that. Whom do I ask about getting access to the downloads section?
14Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Tue Jun 26, 2012 9:16 pm
Crazy Frog is your guy.
15Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Wed Jun 27, 2012 4:57 am
caferacer62
caferacer62
Welcome Scout, the forum is the best place for all things K.
Its full of very helpful folks too.
Good luck with your K.
Bert 2.0
new k100 owner in Oregon 170874
16Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Wed Jun 27, 2012 11:17 am
brickrider
brickrider
Welcome neighbor. You're jumping in the deep end of the pool straight way! What a Face
Well, there's plenty of support here for you should you need it.
17Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Fri Jun 29, 2012 8:04 pm
Hi Scout,
Good to have you with us, it sounds like you have a loose grub screw in the gearbox. Post in the section for engine and transmission and then people will see and comment/advise not all members read the Introduction thread so things get missed.
18Back to top Go down   new k100 owner in Oregon Empty Re: new k100 owner in Oregon Fri Jun 29, 2012 8:35 pm
welcome scout ....
another k bike lives again ....cheers
