1 A few problems here, 1985 german K100, engine cut out, mileage, noises, etc Thu Jun 21, 2012 3:22 am
Rabidchiwawa007
Hey all, new to forum
I just bought a 1985 bmw k100 (german model), which seems to run great, and smooth, etc etc. I'm coming from a 1968 BSA Lightning that I restored from the frame up, so when I see posts about "unbearable vibration", and the such, I sort of laugh to myself; aka, I really don't know much about what to expect from these bikes, only that they consist of more modern technology and, as such, have a ton more parts. I generally know how things work overall, it's just that with the amount of sensors and computer components that can effect each other, it gets a little overwhelming. Also, I'm not all too knowledgeable about these things on a bike.
Okay, the problems:
1.) Random, intermittent engine cut-out, scary.
-This has only happened to me about 3 or 4 times since I got it about a month ago. I believe it only happens when accelerating, around 4-6k RPM, but the engine will just cut out completely for about a second and then come back without my doing anything. This can be, and is, scary when accelerating in a turn due to the engine braking that occurs. And I'm too busy going "oh crap, oh crap, oh crap" to notice if I still have instrument lights, fuel pump sound, etc.
-Things I have tried:
--tighten up battery connections
--reseat and tighten up the connection to the FI computer
--try heating the Hall Effect Sensor with hair dryer while bike is idling (hair dryer sucked, should probably do again with heat gun)
-Things I have not tried:
--probably a ton of things, honestly no idea where to start, any suggestions or ideas?
--replace ignition switch (ignition switch at the moment has a couple "on" positions, and then if you push it a little farther, more "off positions")
--could it be anything with the ignition computer?
--could it be anything else?? I'm totally stumped on this one... and it's dangerous.
2.) Gas mileage:
-Riding around town, I went through three tanks and got ~105mi per tank... aka, under 19mi / gal. I'm using 91 octane pump gas, all tanks from different stations.
--Make sure each cylinder is firing (started, got it warm, and unplugged each cap from the spark plugs one by one to listen for RPM drop) Passed test.
--Check air filter and air supply connections from intake to air box. (Blew out air filter with compressed air, only a little dust came out, can see light through it, and can feel the compressed air come through it) Put filter back in, it seemed fine. Connections are all good.
--Checked tire pressure (tires were about 8psi low each, pumped up to recommended)
--This problem might relate to #4.
--Freeway mileage. I haven't been on a long freeway ride in order to determine highway mileage, but town mileage is so low, it seems like it wouldn't be a ton better on the highway.
--Valve adjustment (Clymer manual says to have a BMW dealership do it due to special tools ><) I do hear a quiet but easily audible tapping sound from valve side of engine.
--Check in injectors in any way (no idea what to check for / how to check)
--Diagnose FI computer? The guy I bought it from told me he had just recently had the fuel pump changed; could the computer need to be set for a different pump?
--Could it be clogged exhaust? If so, is that just something that I check by pulling the pipes and muffler off and shine a light through them?
-Is there anything else I can check? Some of these things don't seem like they'd cause such a drastic drop in gas mileage from the average of 40-55 i see people claim from these bikes around the web.
3.) Battery Drains when bike is off
-Part of me thinks it's just a dud battery, as I had a brand new battery (maintenance free) on my BSA burp acid all over the bike all the time. New battery fixed it for that bike.
--If I don't ride the k100 for a day or two, it either won't start due to low battery, or starts very roughly / slowly due to low battery.
-Things I have done:
--unplug battery (disconnected positive terminal) while I worked on and painted the bike for a few days (had to bump start bike when I finished, battery had died).
--Ordered a new battery, to be here on July 4-5. I ordered an Odyssey PC925L.
4.) Engine misses at high RPM?
-Not too sure about this one. My brother was riding behind me and told me the bike sounded "sick" (in a bad way), like it was missing at high RPM (around 4-7k)
--Tried cleaning inside the spark plug caps (can't think of correct term, but the cords that come from the coils and give power to the plugs) The inside of them look like they have some copper color showing, but are mostly silver / grey colored where the spark plugs would contact.
-I haven't tried anything else
5.) Engine seems to "drop", "lug", and "bog" when I try to grab a small handful of throttle from idle (in neutral).
-I realize it probably has a giant flywheel in it, so I'm not too concerned about this one as that's probably normal behavior, but if not, any idea whats going on?
6.) Noise when letting clutch in, sounds like it's from the clutch area. It sort of sounds and feels like something is "slipping in to place" when I let the clutch in *sometimes*. It doesn't do this all the time. I called the BMW dealership and asked if it needed the splines lubed or anything and said I had no idea when that was last done. The mechanic, who was very knowledgeable and helpful, told me that if I'm coming from a multi plate wet clutch system on a lower power engine (the 1968 BSA set up) and coming in to a single plate dry clutch system on the boxer engine, that's what it will feel like; and that it will feel strange at first, but that it's expected behavior.
-I haven't done anything about this as the mechanic said it was fine, but I figured I'd ask here too as it's not a comforting sound. It doesn't sound "bad", but I suppose I'm just not used to something like that. Any ideas?
Thank you in advance, from the K100 Newbie!!
Okay, the problems:
2.) Gas mileage:
