1 Emulsified final drive oil Tue Jun 19, 2012 11:25 am
mr grumpy
I have just changed the fluids on my newly acquired R100RS 16v and noted that the drained FD oil was badly emulsified. Everything was working fine and without noise, so it is perhaps a tribute to the effectiveness of modern oils that it continued to do its job in this condition. My question to those with vastly more experience of the model than me is what is likely to have caused what I presume to have been water ingress into the FD? I note that the bike has an obviously new gaiter and clips fitted at the FD / swing arm joint, but even if it had been run with a failed gaiter I do not see how water would have got past the pinion seal. Any ideas? The one fluid not yet changed is the fork oil; what grade is recommended for the 16v forks for a 75kg rider and very occasional passenger?
K100RS 16v
