1Back to top Go down   Speedometer needle shaft broken Empty Speedometer needle shaft broken Sun Apr 08, 2012 6:28 pm
greenmachine61
greenmachine61
Hi, I was removing my Instrument Cluster when...*&Shocked !".. dropped on the driveway when I was unscrewing the electrical plug. Humm... if I would have knowed... Result, the needle shaft of the speedometer broke off....
I've been searching all day, to find either a used or new speedometer. The hic is that I did find one but it's in MPH and not in KM. I know that K1000 models works fine with by bike.
So if anyone would know where I may purchase either an instrument cluster or just the speedometer I would really appreciate... The season is early I I don't really like driving with reference only my RPM versus gear...
Thank you in advance...
The Greenmachine from Granby, Quebec.
2Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Sun Apr 08, 2012 8:38 pm
All I can suggest is to keep watch on Ebay in Aust or UK. I occasionally find one there.
If you aer game to pull them apart and reassemble then the shaft would be common to all right up to K1100.
3Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Sun Apr 08, 2012 9:47 pm
japuentes
japuentes
Hi there, mine broke a few years ago, while trying to remove the needle, broke close to the needle. I fixed it with crazy glue and a sleeve made out of a hypodermic needle.
Hope this can help.
Best regards
JAP
4Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Sun Apr 08, 2012 10:18 pm
FreebasserSF
FreebasserSF
Recently I had my speedometer apart and broke the shaft as well and I fixed it with gorilla superglue and a fragment of one of those red skinny straws you stir coffee with. I like japuentes idea with the hypodermic needle better though...
Last edited by FreebasserSF on Sun Apr 08, 2012 10:19 pm; edited 1 time in total (Reason for editing : make post better)
"Build a man a fire and he will be warm for a day. Light a man on fire and he will be warm for the rest of his life."
5Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Mon Apr 09, 2012 6:11 am
www.motorworks.co.uk supply used units and am sure would have one available. They are based in Yorkshire in england and very reliable. However the fixes being offered based on superglue and various other adhesives are perfectly acceptable too, just take a little time.
6Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Mon Apr 09, 2012 6:59 am
greenmachine61
greenmachine61
Thanks everyone for your input,
however I must explain that the needle shaft is broken below the sleeve therefore impossible to glue because to have access to put the glue I must remove the faceplate and then unscrew the grey sleeve then reassemble all and then insert the needle shaft and hopefully wish that the glue didn't dry out.
7Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Thu Apr 12, 2012 7:28 pm
greenmachine61
greenmachine61
I've purchased an instrument cluster from England, however the odo is in miles. So once I've receive it my thought is to take the electronic circuits from my defective cluster and replace it on the new one. Replace the face plate with the km for odo.
I will take pictures of this process and post it so that it might be hepfull to a member.
Again thanks to all for your help! And by the way, Crazy Frog, I will have to drive by your home sometime...
8Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Thu Apr 12, 2012 8:25 pm
Please do let us know how that works out green machine. I've thought about replacing my speedo faceplate with kms as most vehicles in Ireland are UK spec but all our speeds and most distance signs are now in kms.
88KE
Speedometer needle shaft broken Ir-log1188....May contain nuts!Speedometer needle shaft broken Ir-log11
K75RTP - 1994
9Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Thu Apr 12, 2012 9:24 pm
greenmachine61
greenmachine61
Absoletly 88KE, I will post all the details with pictures.
By default I'm sure it's gonna work...
10Back to top Go down   Speedometer needle shaft broken Empty UK to KM Tue Jun 19, 2012 8:22 am
greenmachine61
greenmachine61
I've received my UK cluster but the needle broke through the shipment.
So here how I managed to convert my speedometer from UK to KM.
I removed the mechanical from the UK cluster and installed it in my defective KM speedo.
You must replace two gears in the trip meter.
You can verify the speed accuracy with the software but mine was off by 2 km/hr.
The trip odo works fine in km.
For my broken needle:
Removed the trip odo (two screws in front)
Remove the grey sleeve and replace it by a cutted BIC pen ink tube, about 3 mm.
Inserte it far down in the clear plastic flush to the bottom.
Put some flux on both shaft and heat with an soldering iron (375°C max, it won't melt any palstics)
Then apply a coat of welding.
Final part, with long nose pliers, take the broken shaft and align it to the needle shaft and solder by heating both shaft.
Wait about 10 secondes and there, you shaft is welded and solid.
Hpe this will help !Very Happy
Then
11Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Tue Jun 19, 2012 11:59 am
Good result greenmachine - 2km is a pretty acceptable deviation. Do you have pic of which two gears you replaced?
K75RTP - 1994
12Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Tue Jun 19, 2012 3:04 pm
92KK K100LT 193214 wrote:www.motorworks.co.uk supply used units
For reference, Motorworks will not supply to the US or Canada (but Moto-Bins will) and as stated on their website this is for 'insurance' reasons... ?
13Back to top Go down   Speedometer needle shaft broken Empty Pictures will come soon Tue Jun 19, 2012 10:21 pm
greenmachine61
greenmachine61
Hey Guest in the House...
I don't understand your post.
We are talking about converting UK to KM speedometer.
88KE I will post pictures in about two weeks. If you search on this forum, I think that I've have read a post about broken gears and a website to purchase those gears.
Until then have nice rides...
14Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Tue Jun 19, 2012 11:23 pm
greenmachine61 wrote:Hey Guest in the House...
It's easy. Note that in April 92KK K100LT 193214 mentioned Motorworks as a supplier of second hand parts (as referenced in my capture of their quote). You are in Canada. Motorworks UK isn't a good source for you, unfortunately. My post simply clarifies the point. You may continue.
15Back to top Go down   Speedometer needle shaft broken Empty Thanks Wed Jun 20, 2012 12:36 am
greenmachine61
greenmachine61
Hey thank you for the clairification Guest in the House.
I purchased my cluster via E-bay and not through the site mentionned in April.
Sorry if I was brute towards you but I couldn't understand your post at this time.
Kind regards
16Back to top Go down   Speedometer needle shaft broken Empty Re: Speedometer needle shaft broken Wed Jun 20, 2012 12:43 am
No worries. No brutishness felt. It's always good to have as many spares sources as possible, and Motorworks are otherwise a very good one, it's just a pity they don't do business in North America, for you lot.
Cheers.
