1Back to top Go down   brake issues Empty brake issues Wed Jun 06, 2012 6:29 pm
wez1
wez1
hi i have had my fill this is my first BMW got it cheap so nogripes was a non runner prooved to be a duff fuel pump but now getting ready for MOT and hey presto no brakes at the front:evil:
tried bleeding but got no further i would apreciate any advice on what issues there are with the brake system on these bikes as i have only had kwaks for the past 20 odd years
decided i need a shaft drive and what better than german build so please please any even so small thing i should try would be apreciated as all the lights connected to ABS are having a hayday to themselvesbrake issues 61740 blinking there heads off
in advance thanks to all hwo give advice Smile
2Back to top Go down   brake issues Empty brake issues Wed Jun 06, 2012 6:59 pm
Welcome wez1
first up, don't panic, it normally is the easy things that have cocked up.
You say no brakes, does that mean the brake lever pulls in without any pressure?, is there any release of fluid
down in the caliper or anywhere or maybe just the pistons are stuck in the caliper.
If you have worked on the Kwaka's brakes it shouldn't be too hard for you to pull it all apart. I'm a non mechanical person and still managed to renovate all my calipers and pistons etc with the help from these guys.
I found that I started with the brake lever, piston, master cylinder then brake lines and down to the caliper. Boy was I annoyed but in the end got it done.
I'm sure better people than me will chime in, but don't give up.
Cheers RT
3Back to top Go down   brake issues Empty Re: brake issues Wed Jun 06, 2012 7:20 pm
Welcome wez. There's a wealth of info in the download section but first you need to slide on over to the new members section and stick up an intro. After a few posts crazy frog will give you a password to access then downloads. Also you can do a google forum search on the portal page to find posts on a particular topic.
88KE
brake issues Ir-log1188....May contain nuts!brake issues Ir-log11
K75RTP - 1994
4Back to top Go down   brake issues Empty Re: brake issues Wed Jun 06, 2012 7:29 pm
wez1 wrote:hi i have had my fill this is my first BMW got it cheap so nogripes was a non runner prooved to be a duff fuel pump but now getting ready for MOT and hey presto no brakes at the front:evil:
Welcome to the forum. When you get a mo' please go to the 'Member's Introduction' page and tell us a bit about your bike, oh, and yourself too. And fill us in when you ask a question as to what exactly your bike is. It helps us to make an easier diagnosis if we have that basic bit of info, as it appears nowhere in your question post. Cheers.
5Back to top Go down   brake issues Empty Re: brake issues Wed Jun 06, 2012 8:42 pm
The brakes will work if the lights are blinking it can mean many things but it sounds like you need to fix the actual brakes first and then reset the ABS computer.
I pull the whole lot apart when I get a bike and clean the calipers and pistons and put new seals and O rings in and new pads as well.
Bleed the brakes starting with the ABS modulator and then to the calipers.
The front calipers can be quite difficult to bleed because of the crossover tube from right to left caliper. I have used a vacuum bleeder that I made but they are available from fleabay for around $40.
Once the brakes actually work again you can set about reseting the ABS computer.
Yeah also Wez put up what model of bike you have as it can help when giving help.
Depending on which model you have depends on how ABS is wired.
Last edited by Rick G on Wed Jun 06, 2012 9:52 pm; edited 1 time in total (Reason for editing : Bit more info)
6Back to top Go down   brake issues Empty Re: brake issues Wed Jun 06, 2012 9:38 pm
krambo
krambo
Welcome to the forum Wez - you will find all the information that you need here. If you can't find what you need then just ask Wink
"Aut viam inveniam aut faciam." brake issues Uk-bmw12
http://www.its-personal.net
7Back to top Go down   brake issues Empty Re: brake issues Thu Jun 07, 2012 3:20 am
wez1
wez1
RT wrote:Welcome wez1
Cheers RT
hi i'm a panel beater and have years of experience in mechanics but this has dumfounded me i have checked everything i can think except the electrics.
problem is that when i clamp the pipe to the callipers i have good pressure but on release the pressure dwindles to near zero. just been reading another answer and think the tube bridging between callipers could be the problem will try again never thought of that lol.
8Back to top Go down   brake issues Empty Re: brake issues Thu Jun 07, 2012 3:50 am
wes ...you havent overfilled the master cylinder ?
if so the piston seal will just pull the fluid back up the lines as there is no valve action possible because of the vacume created by the bladder and lack of airspace .
other wise its pretty common that the master piston breather valve (valve situated pretty near a centimeter closer to the presure point of the master piston , different to the fluid feed to the piston assembly propper ) could be blocked with gunk not allowing the pump type action to happen ..
a clean out ...or probe of this hole can be acheived pretty easy from the filler top ...if you evacuate some of the fluid to see what you are doing ...and maybe a pipe cleaner as a probe ...
of corse change all the fluids once completed to keep the whole deal clean and happy .
9Back to top Go down   brake issues Empty Re: brake issues Fri Jun 08, 2012 3:53 am
wez1
wez1
yeah done the usual and made sure it was all clean. am going to ahav another bash at it to day, trouble is that there is fluid coming out when bleeding and no sign of anu air in the syatem. i have pressure when i clamp the front brake pipe and when i release it then try pumping i get zero pressure on the line and that is xausing me my headache. after readin the comments all have posted so far(Smile thanks by the way to all) i am going to try to evacuate the connecting pipe and will then post result. lol
thanks
10Back to top Go down   brake issues Empty Re: brake issues Fri Jun 08, 2012 4:27 am
When you say clamp the front line I presume you mean that you put some vise grips on the rubber line and then try to pump and the master cylinder comes up with a hard lever.
There are 2 rubber lines the first at the master cylinder to the solid line going to the left side modulator and the other where the line from that modulator goes to the right side caliper.
Which one did you clamp because it either means the air is in the modulator and the calipers or just the calipers.
Bleeding the modulators is fairly easy and usually straight forward but as said before the calipers can be very difficult if not impossible.
The K100 I had till recently it was impossible and I made a vacuum bleeder and spent hours getting all the air out.
One thing I have done to other bikes that prooved difficult was to let the system settle overnight with the lever tied tightly to the handlebar, this apparently lets any air in the lines to rise back to the master cylinder.
Another trick is to use a lever to spread the pads so pushing the pistons back into the caliper forcing any air out then pump the calipers back onto the discs.
You can hold or tie the lever in and spread the pads on the right disc while bleeding the left caliper this forces the air to the left caliper then hopefully out of the system
One trick I used recently was to put a thick piece or rubber matting between the pad and disc (you need to use well worn pads to do this) and pump the lever till you get some sort of lever then bleed till fluid stops. This lets more fluid out each time so getting more air out.
One more thing is that the fitting at the master cylinder can sometimes hold air and needs bleeding by just holding the lever in and cracking the bolt. Often a lot of air will come out.
11Back to top Go down   brake issues Empty Re: brake issues Fri Jun 08, 2012 7:16 pm
wez1
wez1
yeah RICK i think you got it right i just read your post after being at the brakes all day i tried all of the things you have mentioned and made on progress i finished up trying a few things one i did clamp the front pipe not the one leading to modulator. i get full pressure then.so i continued by taking each calliper and trying them on there own and they both work perfect and have normal pressure when attached to the master cylinder on their own but when i put them back on the bike the pressure is zero after riggoruos bleeding and rebleading i have near to nopressure so i am at a loss as to the fault the pressure is there when i clamp the front brake line and when irelease it and try it again the pressure is zero ihave no idea what ican be there is no air in the lines of that ia pretty sure . is it possible that yhe callipers are duff? cheers
will keep updating till i find it LOL but any more advice is very welcom if nothing else i can use bike as ballast on back of landy when offroading next week lol
12Back to top Go down   brake issues Empty Re: brake issues Fri Jun 08, 2012 7:27 pm
Let's step back when you clamp the line leading from the master cylinder there is pressure and a hard lever, when you connect the lever direct to the callipers there is a hard lever and pressure? So that says to me the bit in the middle has air in it. When you bled the ABS modulator at the modulator did you get air out? Just had a silly thought when you bled the modulator you didn't by chance bleed the modulator for the rear brakes? Could you describe in detail how you are bleeding the system please just so we can be sure we are all thinking the same process.
13Back to top Go down   brake issues Empty Re: brake issues Fri Jun 08, 2012 9:45 pm
From what you say the line joining the calipers is the problem, just like I had.
Try removing the calipers and inverting them for a while to get the air out of the line, you may need to do it a few times.
One thing I did many years ago on a very stuborne car (MK2 Zephyr) was to connect a long tube from the futherest wheel to the top of the master cylinder and sat in the car ,read a book and pumped the pedal for an hour or more till all the air came out then moved to the next wheel.
I did end up with brakes but the guy next door did ask why I was sitting in the car reading when the house was more comfortable. He was very unmechanical and definately didn't understand the explanation at all and for evermore thought I was just strange, maybe he was right.
Dont worry about using new fluid till you get it right and then replace it with new.
14Back to top Go down   brake issues Empty Re: brake issues Sat Jun 09, 2012 4:28 am
wez1
wez1
hi K Bike thanks but i did bleed the right modulator:) but the problem persists the idea of RICK is my thought to but i tried using seperate lines using a spliter and fitting bleed nipples to each calliper and bleeding seperatly and still get the same darned result i find it kind of wierd is there any other brake setup that will fit in there place with the abs still usable that is my idea next i need the bike to comute to uni (old student lol) so i have a few weeks to tinker around but would much prefer riding than fixing...
15Back to top Go down   brake issues Empty Re: brake issues Sat Jun 09, 2012 6:50 am
Check the rubber lines. This is starting to sound like a problem I struck a while ago with the rear brake. The rubber line had cracked at the fitting on the Modulator but didn't leak out but into the next layer of the hose causing a big bubble in the line and very poor brakes. Put the fingers round each line on the rubber right next to the fitting and pump the lever you may feel the line expanding as you pump.
It drove me nuts for hours and plenty of head scratching till I saw this bubble the size of a marble and BTW it can happen anywhere along the line but at the fittings is more common.
16Back to top Go down   brake issues Empty Re: brake issues Sat Jun 09, 2012 5:31 pm
wez1
wez1
rubber lines are fine checked them over more than once but when finance is better o will be upgrading to braided lines for sure. got to find the problem first gave up today had to paint a couple of bike wheels and replace a doorskin on my uncle's mgb gt lol.need the cash for bits and bobs on the K but tomorrow i'm going to try some more stuff on the bike i am about mad trying Smile
17Back to top Go down   brake issues Empty Re: brake issues Sat Jun 09, 2012 5:32 pm
wez1
wez1
18Back to top Go down   brake issues Empty Re: brake issues Sat Jun 09, 2012 11:29 pm
I know you checked the master cylinder but are all the small holes in the master cylinder free of blockage? One option is to suck the fluid up from the bottom cylinders (put a liberal coat of silicone grease around the bleed nipples so as to stop air being sucked in at that point) then using a modified master cylinder cover and suck with a Mityvac at the master cylinder so any air is encouraged to rise.
Before trying anything else have you followed the bleed process in the BMW manual to the letter? I ask this because different people have different ways of bleeding brakes.
Before you modify the standard setup almost everyone on the list has the standard setup and it works so there has to be a reason (other than demonic possession) why it is being so difficult to bleed.
19Back to top Go down   brake issues Empty Re: brake issues Mon Jun 11, 2012 8:35 am
wez1
wez1
thanks K-Bike i am going to try again to bleed them but first i need to get hold af a new callipeer as i broke the bleeding nipple on the lefthand one Embarassed
i will then try the way the manual says it should b done once i get hold of one. but initially i think the problem is the bridging line as i get good pressure when i connect the callipers directly to the brake line one by one so will keep my progress posted as it goes brake issues 178468
20Back to top Go down   brake issues Empty Re: brake issues Mon Jun 11, 2012 10:22 am
The K1100 has a T piece and seperate lines going to each caliper and was heaps easier to bleed and on the K100 when I got rid of the ABS I had the same setup and it was great, no problems at all.
21Back to top Go down   brake issues Empty Re: brake issues Mon Jun 11, 2012 10:39 am
wez1
wez1
hi Rick been thinking about putting a T piece in an using two bleed nipple's wonder if it would effect the abs function though. it should'nt though but i'm not sure. it would make bleeding an easy thing though. cheers
22Back to top Go down   brake issues Empty Re: brake issues Mon Jun 11, 2012 9:26 pm
The early K11s have the same ABS with a T piece I dont see how it could affect it.
The two bleeders certainly make it easy.
My K75 has the crossover tube and it is a real PITA as was the K100.
23Back to top Go down   brake issues Empty Re: brake issues Wed Jun 13, 2012 6:33 pm
wez1
wez1
i tried that today and been at it for hojurs trying different things lol
discovered something interesting that iam going to try called braided brake lines HA HA i have come to the comnclusion that although one brake has enough pressure wehn connected and the other side has enough pressure when connected but upon connecting both together and bleeding for hours and hours the pressure is still zero, i have to admit defeat. i am going to try graided hoses and then will get back with the results
going to sit down with a wee drambrake issues 292303 now and consider the fruitless day of fails
24Back to top Go down   brake issues Empty Re: brake issues Fri Jun 15, 2012 4:28 pm
wez1
wez1
yo hey got good newsbrake issues 723598 lol thanks t all the helpfull comments and the advice given i have re worked all the piping on the front brakes fitted a tpiece and braided hoses after plenty bleeding and a little cursing i now have front brakes brake issues 318212
but the hair in the soup is that i found that it was due to the anti squeel shim in the brakes that the brakes wer retracting to far and therfor the pressure or distance i had to pul the brake lever was < than could be compensated lol
now i have to tacle the ABS non function but can at last MOT the bike
once again thanks for the advice all of you were willing to part with and i apreceate it lots
i owe you a beer brake issues 502531 or two if we get the cahnce to meet
25Back to top Go down   brake issues Empty Re: brake issues Fri Jun 15, 2012 8:38 pm
Good news Wez if you get a password from Crazy Frog aka Bert you will get access to the downloads page and find how to reset the ABS computer which is probably all that is needed.
26Back to top Go down   brake issues Empty Re: brake issues Sat Jun 16, 2012 1:08 pm
wez1
wez1
cheers will do when i get round to it bit of cash flow problem lol
27Back to top Go down   brake issues Empty Re: brake issues Sat Jun 16, 2012 1:54 pm
I think CF also accept credit cards. brake issues Laughi11
28Back to top Go down   brake issues Empty Re: brake issues Sat Jun 16, 2012 3:38 pm
wez1
wez1
yeah cool if you have one lolbrake issues 44271
