1Back to top Go down   Ignition timing test equipment.  Empty Ignition timing test equipment. Wed May 09, 2012 4:17 pm
giles4060
giles4060
Does anyone have an idea how much the BMW recommended kit is for setting ignition timing in UK?
Hi Giles,
You'll find one at Motobins e-bay shop @ £39.
http://stores.ebay.co.uk/motobinsbmw?_rdc=1
Cheers,
giles4060
giles4060
sidecar paul wrote:Hi Giles,
Cheers,
Thanks Paul....not nearly as expensive as I had feared.
markovivo
Im using Accuspark P8000 and it makes the job very simple.
Ignition timing test equipment.  Timing-Light-QZ-6803C-
http://www.markovivo.com
Here is a how to build your own, the surplus you can use for gas.
Well done Inge, I sort of thought (hoped) you might come up with the circuit. Ignition timing test equipment.  112350
giles4060
giles4060
Thanks Inge that really useful. May be a stupid questiob but could the test circuit decribed here http://hrsbstaff.ednet.ns.ca/bvogel/K100/download/bike-wont-start.htm not be used? Assuning you had tdc - 6 and the LED went out?
thanks inge ....
giles4060 wrote:Thanks Inge that really useful. May be a stupid questiob but could the test circuit decribed here http://hrsbstaff.ednet.ns.ca/bvogel/K100/download/bike-wont-start.htm not be used? Assuning you had tdc - 6 and the LED went out?
They are almost the same at the difference that one uses 12v Leds, and the other is using standard ones (3.3v) whith a 9v battery and inline resistors to drop the voltage.
One is nicer than the other, but when you want to find where you have a problem you don't have the time to make testing material 'pretty'. You want to get an accurate result and both will give it to you.
CF
Ignition timing test equipment.  Frog15Ignition timing test equipment.  Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
10Back to top Go down   Ignition timing test equipment.  Empty Re: Ignition timing test equipment. Sun May 20, 2012 5:31 am
giles4060
giles4060
Brilliant made mine for £6! Might be ugly but it works.
