1Back to top Go down   My sidecar outfit. Empty My sidecar outfit. Thu May 10, 2012 5:50 pm
So here are some pics of my outfit that started life as a blue '86 K100RS
My sidecar outfit. Img12
This picture is from a few years ago, but apart from the front damper units, it is much as it is today.
The forks, subframe and wheels are from Wasp. I had been to a sidecar motocross meeting in Germany, so I thought 'if they can make outfits to stand that sort of work, that's what i want'.
My sidecar outfit. 00711
Although the chair is quite commodious, because the sidecar wheel is inboard, the outfit is quite narrow. From the edge of the sidecar to the end of the rider's footrest, is just under 5' (150cm). Not much wider than a Gold Wing?
My sidecar outfit. Bmw_cl10
The sidecar is a Martello, made in Kent UK. They only made about 20 units and my '88 version is one of the last ones made.
I didn't like the 'universal' chassis that came with it so I made my own, so my chassis will only fit a K with a Wasp subframe. I incorporated a tow bar in the design.
The interior of the body was just bare fibreglass with a seat in the middle. This allowed me to use my immagination to do all the trim, firstly fitting a divider between the passenger compartment and the boot (trunk).
My sidecar outfit. Ssl10730
Huge boot, loads of room for camping kit. I once went to Germany with a Manx Norton engine, most of a 500cc vincent engine and all I required for a week's visit just in the boot.
My sidecar outfit. Ssl10731
This is the passenger's outlook, with a few buttons to play with. The 'buzz' button is to alert me if the passenger needs anything (like a neccessary toilet stop!)
I made the heated seat last year, using the resistance wire from an old car seat.My sidecar outfit. 06910
My sidecar outfit. Ssl10732
A Suzuki GSX750R hugger fills the gap left by using a 15" wheel.
My sidecar outfit. Ssl10733
A view of the Gloucestershire countryside.....oh dear somebody's left a bike in the way.
My sidecar outfit. Slimbr10
So raise a glass to K's everywhere,
Cheers,
2Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Thu May 10, 2012 6:21 pm
Beautiful Paul, a real credit to you. I love the detailing like the elbow rest for the chair passenger. My sidecar outfit. 112350
88KE
My sidecar outfit. Ir-log1188....May contain nuts!My sidecar outfit. Ir-log11
K75RTP - 1994
3Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Thu May 10, 2012 7:04 pm
dee why
dee why
Thanks Paul.
It was great to see all that detail. Quite inspiring.
We don't get to see too many enclosed sidecars over this way.
dee why
4Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Thu May 10, 2012 10:19 pm
That's a really nice job. Very good details and the interior of the chair is downright....commodious as you said! How much does it weigh? Have you done anything with the stock gearing?
5Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Thu May 10, 2012 11:47 pm
cheers paul !!My sidecar outfit. 502531
6Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Fri May 11, 2012 6:25 am
Hi Sean,
The total weight, from our MOT test is 933 lbs, 424Kg.
The standard gearing 31/11 for the RS is used, although a slight reduction is afforded by the smaller rear wheel. I use a full profile 145x15 rear tyre because I don't want to reduce the gear ratio any further! It will still pull away in 4th gear (well, you have to try these things, don't you?) so it's no problem at all.
On the front I use a 145/60x15, which is readily available as the Smart car front tyre.
Thanks for the other comments guys,
Cheers,
7Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Fri May 11, 2012 6:32 am
That's interesting, given that the stock gearing ( for my RT) is 100kph at 4,000rpm, ( indicated)..what is yours doing?
I'm running a 165/15 on mine. I also have a rim which takes the 145/15. At this point, I'm happy with the way it is. With the profile of the car tyre, I notice absolutely no difference to the stock rear wheel set up.
Sean.
8Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Sun Aug 05, 2012 5:36 pm
Following your lead Sean, here are more pictures of my bike.
This is a view across to the village of Kings Norton in Leicestershire.
My sidecar outfit. Sam_0013
And a sunset in Suffolk.
My sidecar outfit. Suffol10
9Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Sun Aug 05, 2012 6:59 pm
Ooops, just saw that I'd asked you about gearing here before...sorry!
Nice pics. Nice paintjob on the bike as well with the pinstriping. Send more pics!
10Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Aug 06, 2012 4:57 am
I am cleaning my laptop and found a pic of a nice rs chair taken at a MOA rally.
My sidecar outfit. Side_b10
My sidecar outfit. Frog15My sidecar outfit. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
11Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Aug 06, 2012 5:07 am
stunning pics paul ...
12Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Aug 06, 2012 7:44 am
BIG D
BIG D
Cool
Paul that is a very nice looking bike and a credit to you,many thanks for sharing the pic's.
BIG DON
13Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Aug 06, 2012 10:28 am
Crazy Frog wrote:I am cleaning my laptop and found a pic of a nice rs chair taken at a MOA rally.
That looks very like the first brick rig I ever saw only in pearlescent white. Sweet rig CF.
88KE
K75RTP - 1994
14Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Aug 06, 2012 6:06 pm
That's nice CF, it looks as though it's got hub-centre steering.
15Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Tue Aug 07, 2012 7:13 am
caferacer62
caferacer62
Great looking outfit you have there Paul. Dont see why the passenger should get a windscreen wiper though, where's the thrill if they can see whats coming. Smile
Bert 2.0
My sidecar outfit. 170874
16Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Sun Aug 12, 2012 6:59 pm
This weekend I've been in the Derbyshire peak district, camping about 1/4 mile from Monsal Head.
En route, somewhere north of Ashbourne on a B road.
My sidecar outfit. Sam_0015
Two of my friends, despite having outfits and a choice of sensible solos, decided to use their tiddlers, a 125 Honda and a 100 Yamaha, just for the hell of it.
My sidecar outfit. Sam_0110
Of course they found the narrowest of lanes and twistiest of roads which suited their bikes but I did manage to keep up with them and we ended up playing in the ford at Tissington.
My sidecar outfit. P8110010
Just another magic w/e, 6 guys with tents, 5 bikes (2 K's, Norton arrived on Saturday with his 75), good pubs, great roads and stunning scenery.
Cheers,
17Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Sun Aug 12, 2012 7:10 pm
STEVE1959
Great photos Paul, keep them coming!!!! My sidecar outfit. 212902
18Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Sun Aug 12, 2012 8:59 pm
Love the fording pic paul? Were the tiddlers swimming in it? Laughing
K75RTP - 1994
19Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Nov 05, 2012 6:25 pm
A milestone for the outfit on Sunday:-
My sidecar outfit. Sam_0310
That's 160,000km in metric money! Now which things have a service life of 100K miles? scratch
20Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Nov 05, 2012 7:21 pm
Now counting in $$$$, it could be this: (You know, everything is bigger and better on the other side of the pound. We get the Chinese way. We can counterfeit anything My sidecar outfit. 652573 ). And..... I even changed the time on your clock the Chinese way My sidecar outfit. 44271
My sidecar outfit. Paul11
Congrat Paul. I know the feeling when you pass this type of mildstone.
Good maintenance and care rewards you with high mileage.
Cheers,
CF
21Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Nov 05, 2012 7:29 pm
lol! I've suddenly overtaken Inge!....at 44.45!
22Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Nov 05, 2012 7:32 pm
Sorry, I had a stressful day at work and needed a good laugh. I will now go to bed with a smile on my face. You may not know, but I like pranks.
Cheers,
CF
23Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Nov 05, 2012 7:39 pm
Yes laughter is definately good medicine.
24Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Feb 04, 2013 6:51 pm
Just had a weekend over in east England, (staying with sidecar friends), frosty nights but dry daytime; it's good to get a decent length ride in at this time of the year. Not many hills in Fenland!.......but they must make big aeroplanes....My sidecar outfit. 723598
My sidecar outfit. A141_f10
25Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Tue Feb 05, 2013 2:34 am
MT350Explorer
MT350Explorer
Great thread Paul, I hadn't seen it before, thanks.
Dave
1991 K100 RS 16 valve
26Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Tue Feb 05, 2013 2:42 am
WHATTT Big fans you guys will try anything to dry the fens out but that is rediculous. Very Happy
27Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Tue Feb 05, 2013 3:21 am
Ajays
Ajays
My hat seems to be off more than it is on. Beautiful outfit.
To make it perfect I would replace the dull tank badges.
Thanks for pictures..etc
Ajays
My sidecar outfit. Th_Kengine_gif
AJAYS
28Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Sun Feb 10, 2013 11:57 pm
My sidecar outfit. SIDE_BM_K100
look at the front wheel on the RS...nice paintjob too........
KKlompy My sidecar outfit. 2854237993
My sidecar outfit. Au-log10
29Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Feb 11, 2013 1:24 am
noice .....some great pics there paul
30Back to top Go down   My sidecar outfit. Empty Re: My sidecar outfit. Mon Feb 11, 2013 3:24 am
Just the thing Cafe needs, I'm sure you could fit a set of roof racks...!
My sidecar outfit. 10_x_110
