1 How to swap out output shaft, engine in? [SOLVED] Wed May 09, 2012 12:17 am
club_c
I have a better output shaft that I'd like to put into the '85 K100RS, just a 6 rivet swap, but I feel the new one is better. Anyhow, I'd like to do this with the engine in the frame if possible. What steps should I take? I'll have to pull the FD and trans obviously, but can I then work under the engine to remove the output shaft, or am I doomed to pull the motor?
1988 K100RS SE VIN 01477554
