1 Now I've done it... Sat Jul 30, 2011 2:54 pm
club_c
While attempting to remove the waterpump for a rebuild I've stripped the socket head on the long RECESSED bolt inside the pump. So how to remove this one now?
Go to page : 1, 2
Avenger GT wrote:Try driving a torx socket into the head of the bolt. It gives much better grip than the hex type.
I think that was mentioned rather early in the thread.club_c wrote:Used a really good 1/4" drill bit for stainless application and it twisted off that bolt head in seconds.
Driving it Arrrggh its like hitting the best china with a hammer, it will break every time. As Rene said it needs to be pulled through by basiclt using a bolt and tightening it while it pulls the seal through.club_c wrote:When I was driving the shaft into the new seal, the seal kinda pulled apart at spring part. I reassembled anyhow, but now think I must have damaged the seal...
charlie99 wrote:i can scan the motobins advice sheet and post it (came with the kit )
but wont be for a couple of days (away job tomorrow but might make it back in time )
hadnt thought about the difference between the bolt and nut on the shaft type and the other way round ...i had thought they were all bolt goes into shaft to hold the impeller ?
Last edited by K Freak on Wed Jan 11, 2012 12:45 am; edited 1 time in total (Reason for editing : Heaps more info)
Toto_jp wrote:thats a bit harsh K-freak you have to be "qualified " now to be a lollipop man !!! and they get a minimum of $25 / hour to play god on the road
Well I suppose I shouldn't be like that just because nature played a lousy trick on thier parents.Toto_jp wrote:thats a bit harsh K-freak you have to be "qualified " now to be a lollipop man !!! and they get a minimum of $25 / hour to play god on the road
Apparently many do just buy a new pump. The telling thing will be how easy it is to turn the pump. You should be able to turn it easily but if you try to give it a spin it will not spin freely in that it should stop as soon as the force is removed. If you can spin it then it is loose. The impeller should sit about 0.4 - 0.5mm (about a fingernail) from the face of the casting and you should be able to push it down to the face but it should spring away as soon as released.club_c wrote:Thanks for that. I really want to solve this for the final time. Probably could have bought a new complete pump for what I've put into seals three times and machining.
Go to page : 1, 2
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Now I've done it...
