1Back to top Go down   pannier lids Empty pannier lids Fri May 04, 2012 9:00 am
col
col
does anyone know if a type 3 outer lid will fit inner of a type 2 pannier
i lost my left side lid the other day
thanks
col
1991 k100lt "the enterprise"
2Back to top Go down   pannier lids Empty Re: pannier lids Fri May 04, 2012 9:23 am
col i think inge already answered this in a previous thread with pics even
might be worth a search ?
3Back to top Go down   pannier lids Empty Re: pannier lids Fri May 04, 2012 9:30 am
+1 on the thread search Col.
The gaskets moved from the base to the lid at some point (T-3 I think) IIRC, so that might be a non runner. Locks differ to early ones too but they could be re-revited I guess.
88KE
pannier lids Ir-log1188....May contain nuts!pannier lids Ir-log11
K75RTP - 1994
4Back to top Go down   pannier lids Empty Re: pannier lids Sat May 05, 2012 7:36 am
col
col
i read that thread first i understand gaskets and locks are different and it is a little deeper i can work with that but what i want to know if that is the only differences or are they a different shape and the two halves wont go together at all
5Back to top Go down   pannier lids Empty Re: pannier lids Sat May 05, 2012 10:17 am
In the thread Charlie reefers to I did write that the two halves (in the combination mk.3 base and mk.1 lid) did fit, but it was a very thight fit.
The opposite way would then be a more loose fit.
Don`t know how waterproof it would be as the opposite edge to the gaskets meets gaskets on the side instead of in the middle.
On the other hand haven`t seen one that is completly waterproof yet, due to the recessed mounting of the locks at the top.
Next issue would be that the mk.3 locks is turned 180o, and the mounting points for the rivets on the inside of the lids is recessed.
But both with gaskets and locks, it would be several possibilities to find a workaround.
6Back to top Go down   pannier lids Empty Re: pannier lids Sat May 05, 2012 10:41 am
great work inge ...thanks
7Back to top Go down   pannier lids Empty Re: pannier lids Wed May 09, 2012 8:57 am
col
col
sorry guys i was reading wrong thread now i understand problem should make sure you are reading right thing before answering when someone tells you something
