Number of posts : 11701
heres a thought ...undo the coils cover and head top /plugs cover and check that the leads to each plug are correct , it is easy to get a couple on the wrong plug .....this could account for the mis-timing and poor ignition spark . the plug information is usually printed on each coil and number 1 is the front of the motor
what plugs have you used ?,,,,if you have resistance lead to the plug tops you wont need the resistance type plugs, it will make the thing rather sluggish at low revs, missfires as well.
