1Back to top Go down   Ignition coil cover? Empty Ignition coil cover? Fri Apr 27, 2012 4:21 am
wikur
wikur
Hi guys!
Does anyone know why BMW decided to loose the ignition coil cover on later models?
Looks nicer with cover but I bet there is a reason.
2Back to top Go down   Ignition coil cover? Empty Re: Ignition coil cover? Fri Apr 27, 2012 4:31 am
i wonder if it could be because of the extended side covers wilkur ...the early series were quite segregated (sidecovers) to just under the seat ...but i bet ..there were heat issues discovered and amended the design so that it minimalised the affect on the riders legs etc ?
3Back to top Go down   Ignition coil cover? Empty Re: Ignition coil cover? Fri Apr 27, 2012 5:00 am
An early attempt at weight savings...?
Ignition coil cover? 652573
4Back to top Go down   Ignition coil cover? Empty Re: Ignition coil cover? Fri Apr 27, 2012 6:34 pm
wikur
wikur
Well,your guess is as good as mine!
Looks way better on the old ones though........
Cheers,Wikur!
5Back to top Go down   Ignition coil cover? Empty why? Fri Apr 27, 2012 9:37 pm
brickrider
brickrider
Call me cynical, but I'm prepared to believe it was to save a few pfennig! BMW omitted a cheap circlip on the airhead transmissions for that very reason and the result was a disaster. So, why couldn't the same bean counters have prevailed on decisions related to the K-models?
6Back to top Go down   Ignition coil cover? Empty Re: Ignition coil cover? Fri Apr 27, 2012 11:30 pm
"Zee motorbike iz performing perrfectly in evry vay. It iz zee rider who haz zee problem."
~BMW technician from Germany visiting our workshop to address a chronic issue with a customer's RT, about ten years ago.
7Back to top Go down   Ignition coil cover? Empty Re: Ignition coil cover? Sat Apr 28, 2012 6:07 pm
BMW did start with this when the 4V models was introduced (K1) which have other coils.
And all 4V models have "open" coils, could be that these coils runs a bit more hot in use?
8Back to top Go down   Ignition coil cover? Empty coils cover Fri May 04, 2012 9:27 am
sven k100
sven k100
i found that the coils were collecting a lot of the heat from the sparkplug area, through the vents in the head , out the back, and collecting in the coils cover, so i've drilled ventilation holes in both sides of the cover, but kept the front intact for appearances sake.
