1Back to top Go down   Oil on the Garage floor Empty Oil on the Garage floor Thu Apr 26, 2012 6:52 am
caferacer62
caferacer62
Damn it went to leave for work this morning and was greeted with a large(500 x 300) puddle of oil on the floor.
Closer inspection seems to be coming out of the releif hole below the oil/water pump. Looks like an overhaul, but main problem is where to get the parts i need by the weekend. Only got the wifes car until tuesday as she needs it for work.
Hmmmm even if i order them from Munich i wont see the bits before monday.
Ahhh well all good fun apparently.
Bert 2.0
Oil on the Garage floor 170874
2Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 7:20 am
bugga bert ....i would have given you mine ,,,,cept its already in ...the oil pump seal is easy ..its the water pump seal thats the tricky one .....
um just check your oil presure switch first mate ...verry close to the same point pop the rubber cap off
3Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 7:22 am
GITH was getting some kits for me with his order from bins. If he has recieved them you can have one and replace it
4Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 7:41 am
Bert, I've PM'd you.
5Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 7:43 am
i should be seeing gith tomorrow ...i can be transporter if it helps ...!!! (great offer rick )
6Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 8:08 am
I got my rebuild kit (and new impeller bolt) this arvo from the 'bins and I can get it to you after lunch on Saturday if you want it.
7Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 8:41 am
caferacer62
caferacer62
Thanks all for great offers of help, have just been talkin to Alby.
He has got a whole pump that i can use till i get parts for mine. Turns out by luck that he is coming down to Caboolture on friday night, so i am going to go and meet up with him there.
All i have to get is a couple of o rings. Might give GITH a call at his work tomorrow see if he has genuine in stock, if not should be able to get from BSC.
At least it gives me a bit of time to get parts and overhaul mine without having to rush.
Again thanks for all for the kind offers. Its what makes this forum so good.
Bert 2.0
8Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 2:30 pm
Halo
Halo
You guys are amazing up there, thats it I'm moving to Queensland not for the sunshine like everyone else in Victoria goes up for but just for the k bike support team.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
9Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 6:16 pm
Could Queensland cope with all 1800 of us?
10Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 6:22 pm
Halo
Halo
Fantastic response Paul I think there going to need a few more tents at Albys
84 K100RS 0014803
93 FZR1000 EXUP
11Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 6:23 pm
What a excellent idea Paul, and then we rename it to Kueensland.
12Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 8:29 pm
Ghost who rides
Ghost who rides
I went out for tea last night and have just read this thread , WOW ... that was quick guys ! You had multiple parts supply options and transport solutions overnight , " I dips me lid ".
13Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Thu Apr 26, 2012 8:51 pm
Really impressed with the way you people reacted to that.
14Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Fri Apr 27, 2012 5:51 am
mike d
Better service than DHL, Fed-Ex etc. Oil on the Garage floor 502531
Mike
15Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Fri Apr 27, 2012 8:14 am
fantastic work again alby ....^5s
16Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Fri Apr 27, 2012 10:55 am
Albyalbatross1
Albyalbatross1
Its always good if i can help someone out at least once a week.
Bert 2.0 should be mobile by sunday night!!!
while i was looking for the reason my headlights went out, just after passing the stop /go on the top of blackbutt range.. I had nearly ten vehicles go past me tonight, Just a fuse..had a spare and a torch, no-one even slowed to offer a hand. (mabey it was the steady rain)
17Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Fri Apr 27, 2012 11:00 am
oh no ! are we going back in there looking for a intermittent short alby ?
that left hand wiring issue again ?
i hope it was just a fuse rating thing ?
glad to hear all is well though
18Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Fri Apr 27, 2012 11:19 am
Albyalbatross1
Albyalbatross1
25 amps is a large fuse for our girls!!! fair amount of powdery oxide in wedge. so me thinks thats a big clue. But most likely a rating issue, bad maths. It was the fuse for the new distribution block. Will look at it sunday.
19Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Fri Apr 27, 2012 8:16 pm
Inge K. wrote:What a excellent idea Paul, and then we rename it to Kueensland.
Oil on the Garage floor 723598 Brilliant Inge!!
Glad you'll be able to make it Bert.
Oil on the Garage floor Ir-log1188....May contain nuts!Oil on the Garage floor Ir-log11
K75RTP - 1994
20Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sat Apr 28, 2012 4:55 am
caferacer62
caferacer62
Well got home from work today and pulled the pump off the old girl. After much mumbling about the previous idiot the rounded off the coolant drain plug. I had it up on the bench. I got the one i picked up from Alby last night(thank you again Alby) and put it beside mine.
I always do this because Murphy lives in my shed and likes to come out at just the wrong moment.
Anyway i discovered that my oil pump gears are different(see pics).
The housing is the same and when i trial fitted without o rings and sealant it goes on ok. Must just be a difference between early and late models. Does anyone know if there is any problems with this or will it be ok. The only problem i can see is the groove in my housing above the small oil pump gear is not on the other one.
Will have to investigate further in the morning and report back with my findings.
Oil on the Garage floor 2012-039
Mines the one on the left.
Oil on the Garage floor 2012-040
Alby's
Oil on the Garage floor 2012-041
Mine.
I stripped mine down and yes the oil seal had seen better days and the spring for the water pump seal isn't much of a spring anymore.
Also the drain line was fully clogged with gunge.
I am going to fit it back up tomorrow all going well, and once i have some parts i will rebuild mine.
Bert 2.0
21Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sat Apr 28, 2012 5:17 am
if you have a look at my reno bert 2 ...you will find i had the issue of a blocked return to sump casting
http://k100rt.aforumfree.com/t1833p250-85-rt-resto-my-attempt-hey-im-not-into-making-a-show-bike#34485
i would guess that the groove would overcome this issue durring reassembly ...and is a better design
cheers mate ...good luck with getting her back on the road .....
i can help tommorrow if you need it ... but looks like youve got everything under control phone --sms if you need moral support mate, im not far away .
22Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sat Apr 28, 2012 5:39 am
caferacer62
caferacer62
Yeah i'm hoping it is all gunna be ok. Am going to have a better look at the front of the engine in the morning. I'd go back down tonight but its fairly hammering down with rain and i couldn't be bothered getting wet(again).
Got pretty wet pushing bikes around at work this morning.
Thanks for offer, might give you a bell tomorrow. I've sent Rick a pm to see if i can get one of his seal kits and i will replace it from Bins. Was Alby's suggestion actually. Just in case.
Bert 2.0
23Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sat Apr 28, 2012 6:30 am
Albyalbatross1
Albyalbatross1
I only suggested you take the offer...to save some time..The brilliant members put the offers forward as soon as they heard you were in trouble.
24Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sat Apr 28, 2012 6:57 am
Bert, I'm rebuilding my spare pump (same model as yours) and I've got the seal kit from Motobins.
All yours if ya want it...
25Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sat Apr 28, 2012 7:21 am
caferacer62
caferacer62
Just giving credit where its due mate, I really appreciate the trouble you have gone too on this one.
Thanks Blakey i'm going to have a quick look in the morning to see if all is ok. i think its just a different oil gallery on the later pump maybe. all the mounts and the drive shaft are the same.
Last edited by caferacer62 on Sat Apr 28, 2012 8:52 am; edited 1 time in total (Reason for editing : brain fade)
Bert 2.0
26Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sat Apr 28, 2012 8:51 am
caferacer62
caferacer62
Update:
Rick has sent me a pm with info on pump differences. Seems that its just a bit lower on the volume delivered side but compensated in the releif valve.
Will post more tomorrow once i get another look at it in the morning.
Bert 2.0
27Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sat Apr 28, 2012 6:42 pm
have to say that the new impeler seems to work really well ...i havent had the same temperatures to compare absolutly ...but notice that the guage is sitting lower than usual .
28Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sun Apr 29, 2012 3:07 am
ReneZ
ReneZ
Good one!! Congrats.
Rene
BMW K100 - 1985 (0030029) Scotland Oil on the Garage floor Rain
29Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sun Apr 29, 2012 4:58 am
caferacer62
caferacer62
Well after the usual sunday domestic stuff was out of the way I got stuck into the pump stuff.
Cleaned all the mating surfaces up, put a new o ring on the oil pump drive and in the groove for the water pump outlet.
Installed the oil pump dive shaft first.
Oil on the Garage floor 2012-042
Then put a smear of loctite sealant on the face of the pump and installed that.
Oil on the Garage floor 2012-043
Put the cover on, connected the hose and oil pressure wire.
Also did an oil change while i was at it, I have only put water in it at the moment because i will be changing over again once i have my pump rebuilt.
The other reason it only has water in it is I filled it with oil then put coolant in it. But some numpty had forgotten to put the bottom hose on, hmmm nice mess on the floor. Thats what happens when you get distracted.
Once again thanks to everbody for the help and info on this, in particular Alby for loaning me his spare pump and riding down to Caboolture in the rain. Man i owe you big time. But i have made a start on your muffler.
Just as a footnote this is the puddle of oil that greeted me on thursday morning as i was going to work. And the start of all this fun.
Oil on the Garage floor 2012-049
Last edited by caferacer62 on Sun Apr 29, 2012 5:57 am; edited 2 times in total (Reason for editing : pic added)
Bert 2.0
30Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sun Apr 29, 2012 5:06 am
good result bert ..i called by but missed you ...
cheers mate ...will be good to see you on the road again ..
the responce was kinda cool ...^5s all
31Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sun Apr 29, 2012 5:23 am
caferacer62
caferacer62
charlie99 wrote:good result bert ..i called by but missed you ...
Sorry i missed you Charlie, was out doing some stuff for the in laws. Should've sent me a txt and i would have made sure i was home.
Agreed the response was great.
Have started a topic on the muffler mods for Alby too.
Bert 2.0
32Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sun Apr 29, 2012 6:21 am
Great effort by everyone.
Glad you're back on the road!
33Back to top Go down   Oil on the Garage floor Empty Re: Oil on the Garage floor Sun Apr 29, 2012 7:20 am
That puddle of oil looks downright demonic! I'm glad you got things sorted too. Weekends, as much as we'd like 'em all to be just for riding, in reality they're for fixing too.
