Go to page : Previous  1, 2
51Back to top Go down   Troubleshooting guidance requested - Page 2 Empty Re: Troubleshooting guidance requested Sun Apr 29, 2012 8:58 pm
C_Mick
Inge K. wrote: It`s quite important if you`re fond of cigars.....and like to have one when puzzling around serving your bike. When disconnecting the hoses when under pressure, you have possibility to spray fuel around where you don`t want it.
I think I would still enjoy a good cigar, but haven't had one for over 20 years. I've told my wife I'll start again when I reach 75. Something to look forward to - the cigars I mean... Smile
52Back to top Go down   Troubleshooting guidance requested - Page 2 Empty Re: Troubleshooting guidance requested Mon Apr 30, 2012 8:44 pm
C_Mick
C_Mick
I will post again when the fuel line is re assembled and I can resume testing . I'm trying to source new o rings for the injectors but can't get the correct size locally. There are a bunch of public holidays in SA; last Friday was "Freedom Day" and today (Tuesday) is "Workers Day". Monday was a 'normal working day' in theory but many establishments remained closed anyway. Oh well...
Chris
Two wheels good...Four wheels bad...
53Back to top Go down   Troubleshooting guidance requested - Page 2 Empty Troubleshooting guidance requested Mon Apr 30, 2012 11:53 pm
I'm not particularly sharp on the whole electrics thing, but I borrowed a set of LED injector pulse testing lights from a mate at an auto garage. You pull the injector connector off the injector (small fiddly wire clip off first) then plug this little LED's 2 wires into the connector and turn the engine over. You can see if a pulse is going through. It's a way of narrowing down your options, by showing if the injector is the problem, or the electrical pulse being sent to it.
Good luck mate, if I can do it, anyone can.
54Back to top Go down   Troubleshooting guidance requested - Page 2 Empty Re: Troubleshooting guidance requested Tue May 01, 2012 2:00 am
club_c
club_c
Regarding O rings, these are the same injectors used on mid 80's to early 90's 4 and 6 cylinder Fords, so if you're really stuck, try a dealer. In North America, the Ford Ranger truck used the same injector, or so I read. Does that help at all???
1988 K100RS SE VIN 01477554
55Back to top Go down   Troubleshooting guidance requested - Page 2 Empty Re: Troubleshooting guidance requested Tue May 01, 2012 3:02 am
C_Mick
C_Mick
club_c wrote:Regarding O rings, these are the same injectors used on mid 80's to early 90's 4 and 6 cylinder Fords, so if you're really stuck, try a dealer. In North America, the Ford Ranger truck used the same injector, or so I read. Does that help at all???
Thanks for the tip, I'll get on to the nearest Ford dealer tomorrow.
56Back to top Go down   Troubleshooting guidance requested - Page 2 Empty Re: Troubleshooting guidance requested Tue May 01, 2012 4:00 am
nino
Hello Chris, my advice regarding O rings is not do ask dealers office. Ask in some general mechanical workshop but bringo the example (O ring) in your hand, like I did. A lost of european cars with injection used that kind and dimension of rings. I asked in electrical workshop in neighborhood and noticed they had a small boxes with different sizes. They gave me set of eight O rings for free.
Regards
57Back to top Go down   Troubleshooting guidance requested - Page 2 Empty Re: Troubleshooting guidance requested Sun May 20, 2012 10:00 am
C_Mick
C_Mick
This has been a long-running saga so I'll cut directly to the chase: I received the new o rings on Friday and replaced the injectors today. On pressing the starter button and with a slight amount of throttle advance, the engine turned over and fired up. Very Happy I let it run for a while and varied the revs until it stabilized at a comfortable tick-over of approx 900 rpm. I ran it some more until the radiator fan cut in as I had replaced the coolant and wanted to eliminate any trapped air in the system.
So what was the likely cause of the problem 'engine turning over but not firing up'? I can't be sure, but I think I can eliminate the fuel system including the injectors as the spray pattern delivered at the injectors seemed fine. I'm inclined to eliminate the ignition system too, as sparks were being delivered at the plugs (but whether the sparks were 'strong' enough I don't know). Later I replaced the plugs just to be certain of them. A possible candidate is air 'starvation' resulting from a partially clogged air filter. Although the filter that was installed had seen less than 2000 miles service, it been on the bike for over 6 years. While I was waiting for the o rings I replaced the air filter in order to eliminate that possibility. I suppose, in the spirit of scientific inquiry I could re-install the old air filter and see whether the engine continues to run OK. But I'm happy to let this remain an open question. I have a few more adjustments to make before I ride the bike after being a long time out of the saddle and I'm keen to get there. I'm grateful to all of you who offered advice and helped me get my '75 running again. I'll raise a glass to you this evening.
Best regards, Chris
58Back to top Go down   Troubleshooting guidance requested - Page 2 Empty Re: Troubleshooting guidance requested Sun May 20, 2012 10:27 am
Well thats good news Chris now we just expect some photos of those great riding roads we hear of in SA and don't forget to keep the shiny side up.
