1Back to top Go down   k100 oil sump Empty k100 oil sump Wed Apr 11, 2012 6:51 am
lesso
lesso
cannot get oil filter out have taken 11 of the 12 bolts out of sump . one bolt as been rounded off. any suggestions ? can i drill it out without causing damage. plz help
2Back to top Go down   k100 oil sump Empty Re: k100 oil sump Wed Apr 11, 2012 7:04 am
You can usually drill the head of those bolts, use a 1/4 in drill.
3Back to top Go down   k100 oil sump Empty Re: k100 oil sump Wed Apr 11, 2012 7:06 am
Go down to your local auto parts shop and buy something called an EZ-Out, or some such brand, they'll know what you mean if they're worth their salt. Screw it in to the small hole you've drilled and carefully tighten it until it 'bites' in. What's left of the screw will be spun in reverse and hopefully come out, easily. Failing that, centre it as best you can with a punch and drill it out in ever-increasing sizes hopefully without damaging the threads as you go. You can pick out the bits of screw. Afterwards tap it out with a 6x1.0 thread tap. Alternately, can you grab the remaining piece with some well-placed Visegrips?
4Back to top Go down   k100 oil sump Empty oil sump Wed Apr 11, 2012 7:20 am
lesso
lesso
thankgod just managed to get it out. now to remove the filter. thanks
