MT350Explorer
MT350Explorer
Hi Guys
Today I changes the TB's rubbers and manifolds. I was able to do it without removing the TB assembly or disconnecting the throttle cable. With new parts fitted the throttle is very stiff and will not turn very much at all so when I start the bike the engine is racing and I cannot change the revs. Any ideas pleaase? I've clearly done something but it does not look like the cable is catching or anything else is snagging it.
Dave
1991 K100 RS 16 valve
Have you checked the choke linkage?
Could be somethings have come out of position, or been bent.
MT350Explorer
MT350Explorer
Thanks Inge
The choke linkage is fine and moves properly. Maybe te throttle butterfly is bent or otherwise damaged, not sure.
Dave
Try to disconnect the cable, and move the butterflies w/o the cable connected.
Then you should get an idea if it`s the cable or the b/f that is the reason to the problem.
check the clamps around the inlet manifold rubbers (below the tbs )...i had a to adjust a few times to get it right, it would bind the linkages if not setup correctly .
MT350Explorer
MT350Explorer
Yeah will do Charlie, I've had a pig of a job getting the clips on, could be one or more is snagging
ReneZ
ReneZ
Indeed, normally the last stub, where the clamp is touching the 'choke' cam if it isn't turned away.
Rene
BMW K100 - 1985 (0030029) Scotland Help - changed TB rubbers and now the throttle is stuck Rain
MT350Explorer
MT350Explorer
It was a couple of stubs catching on clamp screws. Thanks, it was obvious but I couldn't figure it out. Just spent two hours taking it all apart to sort one clamp.....I have good, sound, advice for anyone wishing to do this work Very Happy - put the clamps on the TB rubbers before (can I say again BEFORE) you put it all together. Getting the thread started with the clips I used (which are like the OEM ones on the airbox tubes) is nigh on impossble once the rubbers are in place. In the end I used an appropriately sized jubillee clip as I just couldn't get the thread to bite on the monkey-metal clamp - the jubillee clip was longer so no such problem.
Some of you who are similarly afflicted will appreciate that knowing there is one odd clamp on the machine will be a source of irritation for some time to come.......even if no-one else will notice
Best Smile
Dave
oh well ...we do have a friend that notices just about everything that isnt quite right ...dont we blakey ..?
i recon youve set a good trap dave ....
good onya for getting a solution happening
(mutters to self ...really must get my idle position sorted ...had a brain hickup ...must be the tps holding it open a bit )
Brickee
Brickee
I went to this site and got the Suzuki clamps that others on the forum have suggested rather than use the one time Oerliker? clamps. They're about the same price as the OEM and work so much easier. You can tighten them up when you get everything back together and make sure nothing is binding.
http://www.powersportsplus.com/parts/detail/suzuki/SP-09402-48207.html
"oh well ...we do have a friend that notices just about everything that isnt quite right ...dont we blakey ..?"
Yeah, but it's for your own good! Very Happy
touche my friend ...and we're lucky we have you ..
MT350Explorer
MT350Explorer
Well there you go. Took her for a ride in the clear light of day and what a difference; smoother and more power. Very Happy No spilts all the way through the TB rubbers but corrosion between air intake pipe and top of TB No.1 was probably letting in unmetered air. Same cylinder had a lot of corrosion on the injector electrical plug so a good clean up with contact cleaner may have helped things there. All the TB rubbers were split some of the way so good to replace. While I was at it also fitted new manifold stubbs, stub 'O' rings and injector 'O' rings both ends, and injector to rail clips and then put OEM fuel line on feed and return lines.
On the clips - I replaced the OEM (pictured) one-off disposal type below on the air intake tubes (shown before the work was done)...
Help - changed TB rubbers and now the throttle is stuck Tb110
With the other OEM type that are a solid loop of metal with a screw/captive nut, These were the problematic ones (for me!) to put on once TBs etc were back on as difficult to get the screw to bite as no spare length. If I fitted them and then tried to insert the TB's into the rubbers the TBs did not want to go - too tight. Clips can just be seen below in far right of shot
Help - changed TB rubbers and now the throttle is stuck Tb210
Not sure what the Suzuki ones look like Brickee - but in another 90K miles I'll defintely be looking to do something differently!
Hope this helps someone?!
Dave
Albyalbatross1
Albyalbatross1
blakey wrote:"oh well ...we do have a friend that notices just about everything that isnt quite right ...dont we blakey ..?"
Now where is that choke lever cap????
MT350Explorer
MT350Explorer
Choke lever cap? I could do with one of them..... Very Happy
moto-bins...3 pommy pounds. Cheap as chips.
MT350Explorer
MT350Explorer
Cheers Blakey, I'm going to have to get one Wink
