1Back to top Go down   starter motor keeps running Empty starter motor keeps running Thu Apr 05, 2012 9:15 pm
Ross McCABE
My k100rs I switch the bike off and the starter motor keeps running Have pulled the switch out then connected power and it still runs even without fuses
2Back to top Go down   starter motor keeps running Empty Re: starter motor keeps running Thu Apr 05, 2012 9:29 pm
Welcome Ross!
The starter relay contacts have been welded together, due to starting attempts with low battery voltage or bad battery connections.
Try a few taps on the relay, it could free the contacts.
If no succes, it`s possible to open the relay and clean the contacts.
And get that battery charged before more starting attempts.
3Back to top Go down   starter motor keeps running Empty Re: starter motor keeps running Thu Apr 05, 2012 9:59 pm
Ross McCABE
Thanks Inge K
I did not know which replay to tap so I taped them all and it solved my problem and your right about the battery as I had a similar problem about 20 years ago the memory just doesn't work as well as Id like
Thanks again
4Back to top Go down   starter motor keeps running Empty Re: starter motor keeps running Thu Apr 05, 2012 11:48 pm
this might help ross
posted from the extensive knowledge base of our administrator ....crazy frog....available in the "portal page " links ..."efi troubleshooting "
starter motor keeps running Relay-tray
welcome to the forum mate !!!!
5Back to top Go down   starter motor keeps running Empty starter motor keeps running Fri Apr 06, 2012 7:11 pm
Oh no the secret s out. Now we will have to teach you the knowing handshake.
Welcome aboard Ross.
6Back to top Go down   starter motor keeps running Empty Re: starter motor keeps running Sun Apr 08, 2012 5:28 pm
Charge the battery, and check the voltage when the engine is running about 2,500 rpm so as to be sure the alternator is putting out enough to charge the battery. If that is OK then a new battery may be in the near or mid future.
7Back to top Go down   starter motor keeps running Empty Re: starter motor keeps running Mon Apr 09, 2012 9:18 am
Ghost who rides
Ghost who rides
Hi Ross , how quick are these guys to give the diagnosis ? Glad you got on the forum and thanks for putting me up that night and organisin
g my pannier frame repair , got me home , just !
Cheers G
8Back to top Go down   starter motor keeps running Empty Re: starter motor keeps running Mon Apr 09, 2012 2:36 pm
greecek100rt
greecek100rt
The OEM starter relay costs 65$ . Because of crisis in greece that is a lot of money for me so i decide to buy one Made in China from E-Bay .dont ask me for reliability but it cost to me only 9$ inc tax and shipping cost.
starter motor keeps running 1210
9Back to top Go down   starter motor keeps running Empty Re: starter motor keeps running Mon Apr 09, 2012 8:40 pm
We have not got a crisis in Australia (that is what the government tells us so it must be right) and $65 is expensive here for one of those relays. I have priced a relay that is just as good and it was $16
10Back to top Go down   starter motor keeps running Empty Re: starter motor keeps running Sat Apr 14, 2012 5:02 am
mook
mook
I'm having a similar problem.
where can I find the starter relay?
11Back to top Go down   starter motor keeps running Empty Re: starter motor keeps running Sun Apr 15, 2012 2:45 am
It's in the black box under the tank. Lift the rear of the tank and then lift the lid of the black plastic box. The relay is in the right rear corner of the box. BTW disconnect the battery now even if you dont intend to replace it now or next day as the welded contacts will cause the barrery to discharge totally and cause irrepairable damage that even a good recharge wont overcome completely.
12Back to top Go down   starter motor keeps running Empty Re: starter motor keeps running Sun Apr 15, 2012 6:03 am
Adiwan Djohanli
Adiwan Djohanli
I got spare relays including starter from ebay.co.uk. You can get them cheaper than ebay.com (USA).
I buy and keep many parts for my K100RS mostly I get from the web. For new parts I buy from Motobins UK.
Cheers.
Adiwan Djohanli
Jakarta-Indonesia[i]
