1Back to top Go down   Fuel Sender Unit Empty Fuel Sender Unit Wed May 09, 2012 6:19 am
CanberraDave
CanberraDave
Folks, it looks like my fuel sender unit in my '89 K100 RT is cactus. Does anyone know of a replacement which does not rely on the float? I still only have the bumb dumb light in the instruments and am happy with this. I just want something that is going to light the light at a given level. I have almost run out of fuel twice now. Thought I better mention I get no lights at all. Lamps themselves appear to be working OK.
Thanks in advance for any information.
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
What happens if you get scared half to death twice?
2Back to top Go down   Fuel Sender Unit Empty Re: Fuel Sender Unit Wed May 09, 2012 6:31 am
dave the "empty" indicator can be adjusted ....there have been a few posts about this .....and a wake up call for me .
just as an asside ...when i take off and the indicator is on, i often suffer from fuel starvation on a "quickish launch "...resulting in you guessed it ...no fuel ...then everything ..then no fuel ......um "bunny hops" quite commical ..
but the best way to calibrate the low level sensor is to ...find the level that it doesnt work well ...add 4 litres ...and adjust the low level triger / sensor/lamp for this value ...maybe ?
there were a couple of pics of the mechanism around in here ..ill have a look ....back later
check out this thread dave ..
http://k100rt.aforumfree.com/t3349-testing-in-tank-fuel-sender-unit
3Back to top Go down   Fuel Sender Unit Empty Re: Fuel Sender Unit Wed May 09, 2012 6:48 am
maybe a meter could help mate ....makes judging distances and fuel load real easy
i saw a few advertised in here a little while ago .....and folks are breaking "k" s for parts
4Back to top Go down   Fuel Sender Unit Empty Re: Fuel Sender Unit Tue May 22, 2012 4:45 am
CanberraDave
CanberraDave
Well I have finally got round to pulling out the fuel sender unit (having too much fun riding). The thing came apart in my hand. It was full of gunk behind the plate and all the little wires are broken/worn out. Crying or Very sad
Anyone got a working fuel sender unit they are prepared to part with? Either that or is anyone doing a Motobins order?
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
5Back to top Go down   Fuel Sender Unit Empty Re: Fuel Sender Unit Tue May 22, 2012 4:59 am
nino
I invented most accurate way, much better than any K solution: quick look in opened tank, while on the road. It works 100 percent.
6Back to top Go down   Fuel Sender Unit Empty Re: Fuel Sender Unit Tue May 22, 2012 6:12 am
For a while I had a digital fuel gauge on my K. You open the cap, stick your digit in (you do have a choice of 10...or more if you live in Tasmania), pull digit out and see how much fuel is there. Do NOT lick digit afterwards....or smoke!
