1 The ultimate oil filter tool Fri Apr 06, 2012 5:37 am
Dennis
I recently needed to remove the oil filter from an R12GS and didn't have the filter tool. These filters are (argueably) more difficult to reach than our K engine oil filters as they are external to the engine but fit in a very close engine casting. My solution - Get a product called Rapp-it pipe repair bandage and a new oil filter. The repair bandage is polyester resin and a kevlar-like fabric, the whole thing being contained in an air-tight package. It is activated for use with tepid water. Now, get the new oil filter in a position where the wrap can be wound around the end of the oil filter. Coat the oil filter with any silicone type grease (release agent). Activate the Wrappit product and pass around the filter about 4 times, don't make it too thick or it won't fit in around the filter on the bike. Make sure you push the wet wrap firmly into the filter indentations and continue to mould it till the product goes off in a few minutes. Fashion the remainder of the wrap into a handle that muti-grips can get onto. Tap the cured wrap off the filter and clean it all up, I trimmed mine with a hacksaw so it only engaged the filter indentations. It will be an exact push-on fit on all subsequent oil filtrs and it is so strong it is virtually unbreakable. I was amazed how well it worked, the product must have many more similar uses.
Last edited by Crazy Frog on Fri Apr 06, 2012 5:51 am; edited 1 time in total (Reason for editing : Inserted link to Rapp-it)
