1Back to top Go down   "choke" lever wont stay in position Empty "choke" lever wont stay in position Mon Mar 26, 2012 10:18 am
RSMITH
RSMITH
hi all again.
fan is in and working great.
perhaps some of you have had this problem before, and could tell me how to repair it?
The "choke" lever on the left side of the handle bar will not stay in the "open" position, i have to physically hold it to keep it open.
how can this be repaired , where can i look out for the cause of the problem.
many thanks
The choke lever don`t lock at fully open, only a bit less than halfway of its travel.
Inge K. wrote:The choke lever don`t lock at fully open, only a bit less than halfway of its travel.
My 85 K100rt keeps the choke locked only in the first position when the 1986 keeps it locked in both positions.
The reference # of both housings are different.
If you look closely a the diagram, the 1/2 moon part(Top part of#7)has 2 inprints for the locking ball. Maybe the K100 has only 1????
CF
"choke" lever wont stay in position Choke10
"choke" lever wont stay in position Frog15"choke" lever wont stay in position Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
RSMITH
RSMITH
perhaps i explained it wrong.
i have to hold it open all the time if i let go it just moves back instantly.
i see the diagram thank you - i will have a look at it when i get home thanks.
CF: Thanks, another thing to add to the K75 specific list.
Smitty: Then you`re probably missing the small steel ball and/or spring in the bottom of the choke lever.
Moto Smith
Moto Smith
Mine is the same. The choke lever locks at the halfway point but has to be held open past that point.
Cheers, M
http://www.markaspery.com
sgmayhew
sgmayhew
Cheers, M[/quote]
Ditto for my 89 K100LT
artie86
Hi All,my 86 rt is the same,that's the way the guy I bought it off explained about holding it when starting and then letting it drop back to the other position to continue warmup, Very Happy
RSMITH
RSMITH
ok - thanks,
so it is supposed to lock in the "halfway" position?
my one does not "lock" in any position and moves back to the "closed" position- therefore I have to hold it "open"
will have a look when i get a chance- perhaps the ball on the lock mechanism has fallen out.
RSMITH wrote:ok - thanks,
I have found that many carburetor repair kits have small balls and springs in them and as most mechanics only do half a job some of the kit is left over. They often have a box of such bits if they are anything like me and never throw anything out.
