1 Replacement Rear Drive Unit Wed Feb 29, 2012 4:52 am
CanberraDave
I have been told today by the guy searching for a rear drive unit for my 6/89 K that he has found a reco'd unit with a 32/11 ratio. It is an earlier model 16 tooth spline, so we are swapping my drive shaft for a matching one and the rear drive unit (plus some $s of course). Does having less teeth with a larger surface area make these a bit sturdier? Said items are in the post and should be here in a week or so.
So hopefully this will complete the puzzle and I will have the girl back on the road by the end of March. I may need to start another thread but does anyone know what the four switches on the handlebar pad are for? Starting from the left I have Hazard lights, then one with a horn symbol, then one with what looks like a light and then one that has a blue patch that lights up on high beam (I am guessing for the spotlights that were fitted, I am going to replace these). It is the two in the middle I am interested in as there are a couple of things I would like to wire up so there is an off switch to save the battery and hopefully, if these aren't wired to anything, I can use them. Like an intercom system I have and some heated grips I am getting. It is an ex Qld Police bike.
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
What happens if you get scared half to death twice?
