1 Rear Brake Wed Feb 29, 2012 1:00 pm
snave
Just bought a K100rs (first bmw) which has been stood for ten years,rear brake cylinder had seized , but after a lot of wd 40 and fiddling seems to be ok.
But i am having trouble bleeding the brakes , i seem to have got rid of most of the air , but cant get much pressure , if riding at low speed in first i can lock the back wheel , but any real speed not much brake, am i better of replacing the cylinder as i have spent several hours bleeding!Is it possible to introduce air into the system while pumping the brake without any signs of a brake fluid leak,
Any advise thoughts much appreciated, thank you.
